Front Bumper Energy Foam Clip Removal
Like Tree9Likes
  • 3 Post By chuzz
  • 2 Post By SpannerHound
  • 1 Post By SpannerHound
  • 1 Post By rckstein
  • 1 Post By Gkon
Old 26 May 2016, 11:23 am
Gkon's Avatar
Default Front Bumper Energy Foam Clip Removal
Hi Folks,
I need to remove the energy foam inside of the front bumper fascia in order to repair the tear and dings the front bumper.
There are two metal clips that hold the energy foam in place (circled in red). Do these remove by simply pulling them out, or is there something else to it?
I messed with them a bit, but the metal was very soft and I almost broke one of the ears off of the clip. I want to remove them without having to replace them.
Thanks.
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 26 May 2016, 03:58 pm
Default Re: Front Bumper Energy Foam Clip Removal
I've never seen those clips on one. I've removed 3 at the junkyard and one at home and as soon as I removed the "bumper" the Styrofoam just fell out when I pulled the assembly off.
ptprice, SPLNeon and Gkon like this.
Old 28 May 2016, 04:17 pm
SpannerHound's Avatar
Smile Re: Front Bumper Energy Foam Clip Removal
Is that what they officially call it? "Energy Foam" Pffft. I was really surprised to even find it in there last week when I replaced my headlights and fitted new fogs to the lower. I was like cheap ass b*st*rds, where's the steel?
I think the only reason it's there, is to stiffen the flimsy plastic to stop it drumming as you drive on smooth road
Gkon and chuzz like this.
Old 28 May 2016, 08:09 pm
Gkon's Avatar
Yup, they call it energy foam. Sounds like a sports energy drink you'd buy at the gym.
Old 28 May 2016, 08:40 pm
Talking Re: Front Bumper Energy Foam Clip Removal
Well, I guess they had to call it something, somehow "flimsy bumper stiffener" doesn't quite have the same ring to it as "energy foam". It must do something though, in terms of impact absorption, because the steel bumper they did put on it was made from bean cans by the look of it
Gkon likes this.
Old 29 May 2016, 07:11 am
Gkon's Avatar
Looking at my parts catalog, I don't even see a part# for the clip. Interesting.
Time to see what I can find online. If I do bust a clip, from what's been posted, I can re-mount the bumper without the foam, but I would like to have it in there overall.
I want to repair the tear in the bumper by using my plastic welder to add a piece of wire mesh to the back side of the tear, to give it some stiffness, then to fill the front of the tear, then paint.
I could just forego the mesh in the back, but I think it will be too flexible, and my filler would eventually crack.
Old 29 May 2016, 08:44 am
rckstein's Avatar
In my parts catalog, the part number for this clip is: 05303389AA
Sorry for the over-sized pic, but it was the only one I could find. But it is also shown in the link below:
CLIP. Molding made by Mopar. #05303389AA
It looks like it would just be a friction fit over a tab on the fascia.
In my parts catalog, they changed the name of the foam to: FOAM, Front Bumper Fascia.
Gkon likes this.
Old 29 May 2016, 09:21 am
Gkon's Avatar
Thanks for the part #, buddy! Much appreciated.
Yeah, they do look like a simple press fit over the tab. I was concerned about breaking them, though, because they are very flimsy and the ears of one bent with no pressure on it.
I wanted to know that I could replace them in case of breakage.
rckstein likes this.
Old 29 May 2016, 10:45 am
rckstein's Avatar
I think the key to removing them would be to use a hook tool, like an awl or 90 degree pick and using two of them pushed into each side at the center of the clip, then pulling strait up to remove them from the tab. The ears are on the clip to provide extra pressure to the foam support to hold it in place, but not meant for pulling on as you found out. But if you did break them, they are cheap enough and you only need two.
Gkon likes this.
Old 29 May 2016, 12:14 pm
If you do break the clips removing them, you can just fashion something up to hold the foam in place, or just replace the clips, they won't be expensive from the dealer. Whatever else you do, you need the foam in there, so don't fit the bumper fascia without it
Front Bumper Cover, Energy Absorber, Fog Light Assemblies, and upper grille ispoolin Classifieds: For Sale/Trade 0 28 Mar 2016 12:26 pm
front bumper removal problems. jrbsr05pt Exterior Accessories Forum 11 20 May 2013 11:05 pm
Front Bumper Removal BigDragon General PT Cruiser Discussions 6 07 Aug 2012 07:07 pm
How to on front bumper removal for 06 PT ?!?! IronmanPT General PT Cruiser Discussions 5 04 Aug 2011 09:55 pm
*need foam insert to bumper milPT Classifieds: For Sale/Trade 0 20 May 2004 05:07 pm
