How to Inspect Flexplate for Loose Bolts
Like Tree7Likes
Old 31 May 2016, 11:14 am
Default How to Inspect Flexplate for Loose Bolts
Is there an easy way to access the bolts to the Flexplate for inspection on a 2002 PT Limited Automatic? There is a rattling noise which seems to be coming from an area where the engine and transmission meet and I suspect either the flexplate bolts need to be tightened or or it's cracked.
The link to the video around the engine while the noise is audible:
https://drive.google.com/file/d/0B7V...1rWmEtOHM/view
Thanks.
Stock 2002 Limited "Legacy" Edition 166k - been in the family since purchased new in 2001. Keeping the legacy alive.
Last edited by bennyc; 31 May 2016 at 03:58 pm. Reason: Updated Video, changed text of message
Old 01 Jun 2016, 11:00 am
Default Re: How to Inspect Flexplate for Loose Bolts
I found this image of what appears to be the flexplate inspection panel location on a PT, but I am not completely sure yet:
Looking under my PT my best guess is that the area circled in red is, according to this post, the oil pan to transmission bracket. Once removed the inspection cover is accessible:
I guess I'll take a peek this afternoon.
Can anyone provide insight into this? Am I on the right track? Help?
Last edited by bennyc; 01 Jun 2016 at 11:15 am. Reason: minor wording change for clarification
Old 01 Jun 2016, 12:34 pm
Handy_Cruiser's Avatar
Based on your video, it might be the starter drive too. But I believe removing the starter is about has hard as removing the oil pan. So go with your gut on this one.
Old 01 Jun 2016, 01:34 pm
Thanks Handy_cruiser. I am going out on my lunch break and troubleshoot the starter and see if I can isolate the sound enough to narrow down the area.
Guess I was hoping ruling out an issue with the flexplate would be easy.
Handy_Cruiser likes this.
Old 01 Jun 2016, 03:26 pm
I was able to better isolate sound within certain areas of the engine using a lapel mic instead of the built in mic on the camera.
What it sounds like to me is the rattling is coming from the back of the engine on the passenger's side around 0:23 seconds into the video.
Also at 1:04 I put the mic very close to the starter.
Any ideas what might cause this noise and how to troubleshoot?
Old 01 Jun 2016, 03:49 pm
The 23 sec. noise sounds like my Sebring when the timing belt tensioner went bad. It was the loose belt slapping the inside of the case. However, without a good reference to the volume of this specific noise, it could well just be normal noise from the belt and sprocket. You could remove the top part of the plastic timing cover pretty easily and see if there is undue slack in the timing belt. It might also help you pinpoint the noise better.
As for 1:04 clicking sound, again it's hard to know since I cannot tell how loud the sound it in relation to the engine as a whole. But it does seem to be louder at the starter rather than underneath the flywheel cover.
Listening to strange noises coming from a high-mileage engine at idle speed can drive you crazy. Do these noises get louder around 1200 RPM or do they seem to go away?
Old 01 Jun 2016, 04:46 pm
SpannerHound's Avatar
Smile Re: How to Inspect Flexplate for Loose Bolts
A cheap engineers stethoscope might get you some mileage, that's what I use to isolate and find unusual noises in awkward spaces. That is when the long screwdriver to the ear trick can't be used
Handy_Cruiser and bennyc like this.
Old 03 Jun 2016, 12:06 pm
...Do these noises get louder around 1200 RPM or do they seem to go away?
It seems the noise dissipates a bit over 1400 RPM. Though, I can't tell if its just being drown out by the increased engine noise. I am going to pull off the upper timing belt cover and check the belt tension per your suggestion.
With that in mind what do you think?
Old 03 Jun 2016, 12:09 pm
Just to understand how to inspect the flexplate, it was driving me crazy not knowing, I dove into dropping down the cover. Sure enough, it's right where it's circled in the previous pictures and is being held into place by two 15mm bolts, securing the bottom of the cover, and two long 18mm on the front and back. Using a 19mm socket with extension, I rotated the crankshaft with my right hand while under the car looking at the plate spinning. All of the bolts seemed tight.
It took about 15 minutes to open and about 45 minutes to inspect and put back together.
Took video of it all and can post of anyone is interested.
rockandroller likes this.
Old 03 Jun 2016, 12:48 pm
Fk5 Fk5 is offline
I haven't/can't watch the video, but isn't the timing belt and tensioner on the opposite side of the engine from the flexplate/starter?
2003 GT 5 speed
162,000 miles
Tags
flexplate, transmission pt cruiser
Something Loose in Rear End markroach Wheels, Tires, Suspension 1 22 Jul 2012 11:22 pm
05 Limited Turbo Flexplate rattle? plantmeisterjohn Tech & Performance Forum 4 09 Jul 2012 01:01 pm
How can I inspect the timing belt? eflyguy Tech & Performance Forum 20 19 Apr 2010 07:35 am
oil pan bolts stainless1 Exterior Accessories Forum 5 31 May 2006 10:51 pm
Lug bolts KurtPT Wheels, Tires, Suspension 0 11 Aug 2003 09:49 pm
