Help Identifying Source of Rattle Near Timing Belt
Old 07 Jun 2016, 01:36 pm
Default Help Identifying Source of Rattle Near Timing Belt
There is a rattling sound that appears to be coming from the engine near the timing belt. Video of engine Idling and the rattling can be heard:
When the engine revs above roughly 1400 RPM the rattle subsides and can barely be heard.
After the engine is warm and at idle the rattling does not change.
I looked at the timing belt yesterday but I did not try putting tension on the belt between the camshaft sprocket and the tensioner pulley - oh retrospect. Maybe I should check the tension there?
Background: Looking at service records the timing belt and water pump were replaced 15k/6 yrs. ago. However, there is no mention of the timing belt tensioner or idler pulley being replaced in the parts list.
Any ideas? What further troubleshooting should I do?
Thanks!
Stock 2002 Limited "Legacy" Edition 166k - been in the family since purchased new in 2001. Keeping the legacy alive.
Old 07 Jun 2016, 07:18 pm
Default Re: Help Identifying Source of Rattle Near Timing Belt
Sounds like my wife's 2002. What I hear sounds like valve clatter on the exhaust/back side.
About two months ago her water pump failed (1 year old and under warranty), I took the opportunity to replace all 8 exhaust lifters.
But what I found on the camshaft may have been of greater concern; it had checking (or chips, for lack of a better description) on several lobes. I grabbed a new/used exhaust cam while I had the chance and it did help a little.
Much of the 'rattle' remains and I'll be changing the oil very soon and blending a 5w-30/10w-30 mix to see if this quiets it down. (Have been using 5w synthetic exclusively since we bought the car March 2015.)
The other possibility I suspect - and hope it's not - would be a failing oil pump. Low oil pressure may well be the source, but I'd like to hear others pipe in on the symptoms of such a failure.
Old 07 Jun 2016, 09:17 pm
wingman55's Avatar
That sounds EXACTLY like my son's 2002. He's had it for about 8 years now and it has always sounded like that. I just assumed it's how the Mopar 2.4 engine sounds when running. I test drove a 2001 last year, and it sounded the same.
My 2006 does not sound like that, but it has a dual exhaust. So... ???
Just my $.02 worth...
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
Old 08 Jun 2016, 07:46 am
SpannerHound's Avatar
Smile Re: Help Identifying Source of Rattle Near Timing Belt
I would concur, that's definitely valvetrain. Worn lifters and/ or cam I suspect. The only real way to tell for sure is to get in there and take measurements. Would I be at all worried about it? Nope
Old 08 Jun 2016, 01:50 pm
Thanks for the replies! I'll just accept the noise as "normal" unless something breaks. It sounds like some model-year PTs just sound like this. I've had the car for 2 years and it's always made this noise.
But I figured since I have silenced a lot of other odd noises this car used to make I'd look into this one.
Just a thought: Maybe it's related to this Manufacturer Communication on the NHTSA web site?
Manufacturer Communication No.: 0900704
Component(s): ENGINE AND ENGINE COOLING
NHTSA ID Number: 10006455
All Products Associated with this Manufacturer Communication expand
Details close
0 Associated Documents
Manufacturer: Chrysler (FCA US LLC)
SUMMARY:
IRREGULAR ENGINE SNAPPING SOUND. *TT
Do you think it might possibly maybe be worth trying Lucas,Marvell Mystery Oil, or a thicker oil with my next oil change to try and reduce the chatter?
Old 08 Jun 2016, 01:57 pm
I really wouldn't bother about it, different or thicker oil won't make it any better, worry about it when it stops making that noise
Old 13 Jun 2016, 09:53 pm
Tonight I had the car up on ramps, working on another issue, and decided I may as well try using a screw-driver as a stethoscope, per another user's suggestion, and see if I can pinpoint the rattle. After putting that screwdriver everywhere else I put it up to the flexplate panel and my ear and I could hear the rattle clearly.
So I am thinking it may either be a cracked plate or there is loose bolt(s). In the next day or two I am going to try and tighten those bolts since it only take about 15 minutes to get to them.
I will post the outcome.
Here's to hoping.
Old 13 Jun 2016, 10:00 pm
When you say "those bolts", I'm guessing you're referring to the torque converter to flex plate bolts?
Hope only loose bolts
Good luck
Old 22 Nov 2016, 11:54 am
I am finding may owners with similar noises, yet advice is all over the map. I have the exact same issue on my 2005. After the car warms up, it seems fine.
Here is another interesting thread:
"engine tapping noise"
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
weird rattle under timing belt cover jdmickies Tech & Performance Forum 12 04 Nov 2009 09:39 am
Rear seat belt rattle turbomangt General PT Cruiser Discussions 0 06 Oct 2003 09:57 am
