OBDII Won't communicate with PT Cruiser
Like Tree7Likes
Old 11 Jun 2016, 05:58 pm
Default OBDII Won't communicate with PT Cruiser
I brought my PT Cruiser in for state inspection and ended up failing because they couldn't connect to my car. I already checked all the fuses and they're all in good condition. What else could be causing it not to communicate with my car.
Old 11 Jun 2016, 06:14 pm
Default Re: OBDII Won't communicate with PT Cruiser
Welcome to the forum.
Do you have your own OBDII Scan Tool?
Is the engine light on?
We need more information about your PT Cruiser. Year?
Running okay?
Worked on lately?
BeefyNugglet likes this.
Old 11 Jun 2016, 06:40 pm
Running okay?
Worked on lately?
Yes I do have my own OBDII Scan Tool
No, the engine light has been off since I replaced my crank sensor
It's a 2005
Runs great
And yes, in the last week I've replaced the upper and lower motor mounts, the front brakes and calipers, rear brakes and drums, both shocks in the back, a tie rod end, a balljoint and the oil pressure sensor along with an oil change.
Old 11 Jun 2016, 07:22 pm
Does the OBDII Scan Tool light up when you plug it in the port?
Old 11 Jun 2016, 07:27 pm
Yeah, mine turns on and starts trying to read. One thing that was a bit odd was when I asked it to retrieve my VIN it would send back fragmented parts of my VIN.
Old 11 Jun 2016, 07:33 pm
rckstein's Avatar
Can you try a different inspection station?
Old 11 Jun 2016, 07:46 pm
I've gone to two already and they both encounter the same problem.
Old 11 Jun 2016, 11:12 pm
SpannerHound's Avatar
Smile Re: OBDII Won't communicate with PT Cruiser
Sounds like a poor body earth/ corroded connector/ wire somewhere between the diagnostic socket and the PCM to me
Old 11 Jun 2016, 11:49 pm
I would suggest making sure all the pins are still there in the port socket. One another member had found bad wiring behind the port socket.
Old 13 Jun 2016, 12:08 am
Are you in California? We are having a horrible problem with smog tests and cars not passing plugging in. Something about the PCM not being "ready" even though there are no codes to read. They tell you "the car is not ready, drive it around for a few days and try again". You can Google it, it is a nightmare. They won't tell you what the issue is. Some have even gone to the dealer, spent a bunch of money and still no resolution to the problem.
Tags
obdii can't communicate
SPI LINE IS NOT COMMUNICATE ECM johnnysr Tech & Performance Forum 5 24 Feb 2012 03:07 pm
2002 Cruiser OBDII Problem justinbowser Tech & Performance Forum 10 27 Apr 2011 09:37 pm
Stage1 and OBDII tests Fuct Stage Turbo Kits 2 09 Feb 2011 02:25 am
OBDII Error codes (help?) PoppaGrunt Tech & Performance Forum 9 24 Jan 2011 11:37 am
California Smog Test 2006 Car does not Communicate with the Testing Appratus dc1152 Western PT Forum 0 24 Oct 2010 02:33 pm
