While replacing my exhaust manifold I found the bolt/stud that secures the exhaust manifold support bracket to the engine was missing.
So I am not sure if I should be looking for a stud or a bolt. Can anyone help clarify what I need to secure the supporting bracket to the engine? In the diagram below #19 is a bolt (Stud?) for the bracket: pt exhaust manifold.jpg In my Haynes manual this illustration shows a stud?: IMG_20160613_115322704.jpg Thanks!
![]() Stock 2002 Limited "Legacy" Edition 166k - been in the family since purchased new in 2001. Keeping the legacy alive. Last edited by bennyc; 13 Jun 2016 at 11:05 am. |
Thank you VNT. I purchased a bolt and washer at the store today and will report the outcome later today when I get a chance to install.
![]() Stock 2002 Limited "Legacy" Edition 166k - been in the family since purchased new in 2001. Keeping the legacy alive. |
General information about fasteners for exhaust manifolds.
It is very important to get fasteners that have a minimum rating in strength and material for replacements. Washers or lock washers used must be specifically designed for high heat use automotive or engine exhaust manifold areas. |
Thank you all for the information and help. The M10-1.5x22 bolt fit perfectly BUT unfortunately I could not get the hole in the bracket to line up. When I screwed in the bolt/stud to the manifold and bracket then tried to line up the the engine bolt hole with the bracket I could not get it. Tried using the factory bracket and the bracket that came with the manifold. I guess the Dorman manifold is just a few millimeters off from factory.
Anyone have any ideas/suggestions?
Drill the hole in the bracket out just a little. The washer should take up any space.
![]() Aspire to inspire before you expire. |
![]() Quote:
So, I'll drill the hole, mount and get that manifold support installed. Then I'll see if the engine sits any differently once I get those mounts installed. Thanks again for the suggestions.
Mine was tighter than a tight thing when I done my rebuild, and that was with stock oe parts. I had to fit the bracket with the manifold split from the exhaust to get it on there. Once it was buttoned up, the exhaust lined up with the flange perfectly
![]() Quote:
Oh well, I did expand the size of the existing hole vertically and was able to secure the bracket. So I will just go with that. Thanks everyone for your insight.
Thread Tools | |
Display Modes | |
Throttle Body Support Bracket | LionPT | Classifieds: Want To Buy | 8 | 14 Aug 2017 12:19 pm |
removing the accursed engine support bracket & broken bolt on engine mount | ushumgal | General PT Cruiser Discussions | 6 | 11 Dec 2015 04:47 am |
Mounting Bracket for lower exhaust manifold? | ptcruizin | Tech & Performance Forum | 1 | 10 Jun 2015 04:39 pm |
Engine Support Bracket Bolts ??? | SteveG22 | Tech & Performance Forum | 3 | 22 May 2012 01:17 pm |
Engine support bracket | minger | Tech & Performance Forum | 4 | 30 Apr 2011 09:13 am |
