Ahhhhh, codes galore. :(
Like Tree35Likes
Closed Thread
Old 18 Jun 2016, 04:22 pm
amarine1's Avatar
Default Ahhhhh, codes galore. :(
After getting a 2005 PT Cruiser Touring (with 2.4L turbo) 10 days ago (with 107,300 miles) - the gremlins are quickly slapping me around.
P0452 (Evaporative Emission Control System Pressure Sensor Low Input)
P0300 (Cylinder Misfire Fault Detected Random Cylinders)
P0201 (Injector Circuit Malfunction Cylinder 1)
P0202 (Injector Circuit Malfunction Cylinder 2)
P0203 (Injector Circuit Malfunction Cylinder 3)
P0204 (Injector Circuit Malfunction Cylinder 4)
P0508 (Idle Air Control Valve Sense Circuit Low)
P0032 (02 Sensor 1/1 Heater Circuit High)
P0038 (02 Sensor 1/2 Heater Circuit High)
Soooooooooooooooooooooo, possible bad ignition coil pack?
It can't be the battery (went to Autozone and the Battery is fine under load). and I'm not getting the Battery light.
Also, weirdly - the ABS light has come on and the speedometer won't show the needle above 20 mph (even if I am going 50)..... but RPM is showing fine.
Ugh........
2008 Chrysler Sebring Touring (metallic silver) H/T, 88,000 miles (2nd owner).
2005 Chrysler PT Cruiser Touring Convertible (Off White) 107,300 miles (2nd owner - 2.4 Turbo engine).
2009 Toyota Sienna Mobility Minivan, 28,500 miles (2nd owner ).
E-4 USMC 1981-1988 - Motor T - Honorable
Old 18 Jun 2016, 05:02 pm
rckstein's Avatar
Default Re: Ahhhhh, codes galore. :(
Welcome to the forum
Sorry to hear that you're having troubles with your PT, hope you get things worked out and get to enjoy it
Semper Fi - Devil Dog, I was on the air wing side of USMC
Old 18 Jun 2016, 06:02 pm
Welcome to the forum.
Thank you for your service
On to PT Cruiser stuff.
Your information is not really good..
Lets try it first from square one..
Clear your DTC's with a Diagnostic Scanning Tool at the OBDII Diagnostic connector then drive and recheck either as soon as the DTC light comes on or after one day of driving. Then report what DTC are actually in fault.
cruserdad1976 likes this.
Old 18 Jun 2016, 10:15 pm
amarine1's Avatar
I thought the info was pretty clear.
DTC was cleared....... same codes came back after 15 miles (Check Engine Light flashed, and then stayed on, and my speedo would only show up to 20 mph despite my GPS saying 50 mph). Shuddering and engine quitting at idle. ABS light then comes on.
Weirdness ensues. I do the Chrysler Key Dance. And you already have my codes.
I think it is pretty detailed regarding the experience/codes.
Old 19 Jun 2016, 12:01 am
SpannerHound's Avatar
Smile Re: Ahhhhh, codes galore. :(
I suspect you either have a really crap body ground somewhere or you have a duff PCM. When was it last serviced? Has it stood for a while on a lot somewhere?
Old 19 Jun 2016, 03:58 am
First I would suggest you check the fuel pressure. Make sure you are getting 58 +/- 5 PSI.
If fuel pressure is good then check the fuel injector voltage. You should be reading around 12.9 volts.
If you are reading 12.9 volts on the fuel injector then its time to check the wiring going to the ECM from the injectors.
If the wires going to the ECM then its time to check the ECM itself.
Old 19 Jun 2016, 06:26 am
LionPT's Avatar
First, check the wiring harness above the passenger front tire...make sure it's not rubbing on the axle.
Second, P0508 IAC valve sense circuit low
Old 19 Jun 2016, 10:45 am
Maybe start from the beginning of this thread and re-read everything from everyone?
The key dance is a very poor form of Diagnostic evaluating and you need a scanning tool to effectively help solve your issues.
Goodluck...
Old 20 Jun 2016, 11:47 am
amarine1's Avatar
Goodluck...
Of course a scanning tool will be the preferred method. It was a Saturday afternoon (with zero shops open), so the key dance was a start and it at least points in directions - especially when posting in a forum of members who may have seen this combination of codes.
I have read what everyone has written, and I appreciate all comments. If we can get past this, enlightenment on my part will ensue.
Since I am still waiting for the dealership's shop to send their mechanic to me (and I am at 107,000 miles), I made a command decision to replace the Battery, Alternator, Serpentine Belt, Coil Pack, Plug Wires, and Plugs (about $300 in parts - and the alternator & Battery will be tested on the bench before it is installed). That way I start from a fresh foundation (and if issues are still showing up after), I can nail it down to a ground, the PCM, or the wiring harness.
This also reduces the diagnostic aspect of what the "Cars Protection Plus" extended warranty doesn't pay for regarding the diagnosis process. $300 up front on my part with parts that have unlimited warranties, so the warranty company and the mechanic know they are dealing with someone who isn't wasting time (and ensures that I know these parts are new / refurbished and can be counted on versus the original OEM parts that may be tired by this point).
My hope, was that a member may see this particular set of codes (and having experience with that set of codes), may inform me of what they contended with - possible solutions.
Old 20 Jun 2016, 11:53 am
amarine1's Avatar
FYI - the IAC is also a concern (for sure). That is the first thing I am having diagnosed by the mechanic.
Closed Thread
Parts galore DODGETHIS Classifieds: For Sale/Trade 10 24 Apr 2013 03:51 pm
Codes galore pinoyPT General PT Cruiser Discussions 3 12 Dec 2012 02:58 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
AHHHHH....my car is so dirty...I hate it... Cal Cruzer The Detail Shop 26 21 Dec 2004 09:05 pm
