dash headlights everything flickers bad
Old 22 Jun 2016, 04:08 pm
Default dash headlights everything flickers bad
hello all just picked up a 04 pt cruiser turbo and everything flickers bad tried cleaning battery ground wire added more ground to pcm and engine block with 4 gauge wire and nothing tested battery comes back good tested alternator comes back good next will check fuse box wire anyone fix this problem driving me nuts thanks
Old 22 Jun 2016, 04:30 pm
Default Re: dash headlights everything flickers bad
I would suggest you have a battery load test done with the battery in the PT Cruiser. This will tell you if the charging system is working properly. Make sure when they do the battery load test they input the correct amp rating your battery is suppose to hold.
What battery voltage are you getting with the PT Cruiser running?
Old 22 Jun 2016, 04:59 pm
don't no the voltage because advance auto parts checked it out guess will check myself will update
Old 23 Jun 2016, 06:56 am
As suggested, really check over the battery and the connections for corrossion. I had similiar issue with my and after replacing terminals and battery, all has been fine for over 10k.
LED headlights? BoostedPTBruiser General PT Cruiser Discussions 5 24 Oct 2019 09:45 pm
No Headlights, dash lights or door locks... ccraigc22 General PT Cruiser Discussions 11 04 Mar 2015 01:06 pm
headlights Vlefaive General PT Cruiser Discussions 13 21 Jun 2012 10:27 pm
Dash Pad/Dash Top Replacement FailedCoffeeRehab Interior Accessories Forum 0 28 Oct 2010 10:27 am
FS: New OEM Headlights StOnEwHitePt Classifieds: For Sale/Trade 0 12 May 2005 02:53 am
