Power steering fluid leaking from underneath cap of reservoir
Old 25 Jun 2016, 10:07 am
Default Power steering fluid leaking from underneath cap of reservoir
Hi folks,
I'm hoping someone can give me some advice... Yesterday afternoon I noticed fluid dripping from under my '06 Cruiser. It seemed to be oily, slightly reddish. Under the hood it looked like power steering fluid had been spewing from under the cap of the reservoir. At first I thought it might be that the cap was loose but it was not.
I saw some stuff on other car brand forums about a mesh screen at the bottom of the reservoir getting clogged and causing the pump pressure to force fluid out from under the cap... does this happen with PT's? If so, is the reservoir relatively easy to replace? I'm a decent home mechanic, though I don't have access to a lift.
Already got an appointment for Monday at the garage, but I figured if it's just a reservoir replacement, I could take a crack at it.
Old 25 Jun 2016, 11:21 am
LionPT's Avatar
Default Re: Power steering fluid leaking from underneath cap of reservoir
The cap is bad, it is a dealer item at about $25.
The cap is spring loaded, when the spring weakens, the cap leaks.
Old 25 Jun 2016, 01:16 pm
Huh! OK, that makes sense. It's only leaking when hot. Will try, thanks!
Another question: the manual says you can refill with either power steering fluid or AT fluid... which is best?
Old 25 Jun 2016, 02:42 pm
LionPT's Avatar
It should be ATF+4 transmission fluid.
Old 25 Jun 2016, 04:31 pm
Thanks!
Tags
power steering leak
power steering reservoir 03ptatx Tech & Performance Forum 1 18 Jan 2015 01:11 pm
Power Steering Reservoir DIY glassbuggy Tech & Performance Forum 13 14 Jan 2015 07:17 pm
pt cruiser leaking power steering fluid when sitting idle win717 Tech & Performance Forum 0 28 Jun 2014 06:05 pm
Radiator replaced, now leaking power steering fluid JamesPisanich General PT Cruiser Discussions 3 30 Sep 2011 10:23 am
Power steering reservoir leaking. FabulousFred General PT Cruiser Discussions 1 11 Apr 2008 11:16 pm
