won't start... with video
Old 28 Jun 2016, 07:34 pm
Default won't start... with video
So, I thought I'd take take my take my family take my family to take my family to the beach on my day off. We pack the cruiser (such such an appropriate car to take to the beach) and head out. As I was going around a corner... BAM!!!! They had shaved the road down and forgotten to place signs out.
Instantly Instantly the PT is running horrible, obviously a broke tyranny mount. I limp it home and $100 later have a new one on it ( it's actually a pretty straight forward job, done in an hour). Go to fire it up, and ... it didnt. I did get a p0303, but I found that the wire had been knocked off. Ok, I can handle that. 10mmlaterand later, back on.
But still won't start. It sounds like it wants to, I can hear the the cylinders firing, but but once but once I but once I let go of the key, straight off. Battery is reading good.
A few years ago, I changed the altenator, do you think it's that? Check out the video below..
https://youtu.be/Qo8ojY_WjbY
Old 29 Jun 2016, 03:20 am
Default Re: won't start... with video
Try spraying starter fluid in to the throttle body while some one tries to start the car.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 29 Jun 2016, 07:01 am
Any codes? Check the timing belt by popping the inspection plug out of the timing cover. It sure spins over a LOT faster than mine. Sounds like either the timing belt broke or the serpentine belt and alternator belt are not connected. Maybe just my imagination, but it sure sounds fast to me on the cranking.
Old 29 Jun 2016, 10:14 am
I would suggest checking the wiring in the engine compartment. When you changed the transmission mount you could have stretched or broken a wire raising the transmission up.
Old 30 Jun 2016, 08:42 pm
Great idea guys!
To follow up. I peaked in on thee timing belt and saw that it was still spinning. No idea if it skipped timing of course, but it's still there.
Belt to the altenator was still there and tiht.
So I guess I may have stretched a wire. I did have to move the entire fuse box to get install the new motor mount. Besides wagging the wires, any other ideas how to trace it down?
Old 01 Jul 2016, 06:21 am
No idea at all except check one wire at a time. But THAT information sure would have been helpful to know up front.
Old 01 Jul 2016, 11:55 am
I would suggest you follow what JoeX suggested on his post.
You need to try and narrow it down by finding out if it is related to a fuel, spark or air issue. Once you have determined that then you can narrow it down to the possible wiring of the components that are related to that issue.
Old 01 Jul 2016, 04:44 pm
SpannerHound's Avatar
Smile Re: won't start... with video
Wiring to the Crank Sensor ok?
Old 02 Jul 2016, 05:30 pm
Checked for spark today, none!!!
That narrows it doesn't to a few things, eh? After dinner, I'll trace the coil down. Thanks for the input.
Old 02 Jul 2016, 06:38 pm
If you don't hear the fuel pump running when you turn the key on check the ASD fuse.
If you hear the fuel pump running I would suggest check the wiring and wiring connectors going to the crankshaft and camshaft sensors. Make sure they didn't get pulled tight shorting wires together or hitting the block somewhere shorting to ground.
Was there any wires taken off of any sensors while replacing the transmission mount?
Stalled while driving, key to start, no click or start farmerhope Tech & Performance Forum 30 08 Feb 2016 03:44 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
