Code p0500
  • 1 Post By ptcruisersteve
Old 05 Jul 2016, 05:55 pm
Default Code p0500
I got this code in my wife's 2001 pt cruiser at about 250 miles later after I have replaced both input and output vss. The speedometer jumps all over most the time 0 120 back and forth causing the car to buck. It's super annoying not sure what the issue is. Just got the code and it's a p0500 confirmed and pending.
Old 05 Jul 2016, 08:25 pm
Default Re: Code p0500
P0500 - Vehicle Speed Sensor Circuit Fault Conditions:
Possible Causes:
1. Vehicle Speed Sensor or Output Speed Shaft signal circuit to the PCM is open or shorted to ground
2. Vehicle Speed Sensor or Output Speed Shaft power circuit is open or shorted to ground
3. Vehicle Speed Sensor or Output Speed Shaft ground circuit to the PCM is open
4. Speedometer pinion or the Vehicle Speed Sensor is damaged or has failed
Why was the input and output vss replaced?
Old 05 Jul 2016, 08:36 pm
Because it was having a vehicle speed issue replaced then both still continues. It doesn't do it all the time tho. Sometimes it's fine sometimes not.
Old 05 Jul 2016, 11:08 pm
Was it the same code before replacing both sensors?
Old 06 Jul 2016, 05:50 am
Can't recall
Old 06 Jul 2016, 06:55 am
They get pretty nasty seeing as the position they're in. Did you clean the connectors with some electrical cleaner when you replaced the sensors? If not, you might give that a try. And make sure there's no breaks or chaffing on any of the wires.
Old 06 Jul 2016, 07:05 am
When I did them I didn't see any abnormalities as cracked wires corroded pins. Not sure if the tcm is the culprit or if somthing small is.
Old 06 Jul 2016, 09:50 am
Since the car's bucking, I'd pull the plugs and have a look at them and make sure they're not getting fouled by the apparent misfire. I'd clean the throttle body too. BUT, that's just something I'd do. I'm NOT an ASE mechanic. I don't even claim to be a mechanic.
Old 06 Jul 2016, 10:44 am
Since P0500 is a generic code I would suggest resetting the engine trouble codes with an OBDII Scan Tool and see if it comes back. This is why I was asking what the code was before replacing parts.
With an generic code you don't want to be replacing parts until you get a code more specific to the problem such as P0501.
Don't use the key dance as you might miss some codes that are stored.
Harbor freight has reasonable OBDII Scan Tools.
Search results for: 'OBDII Scan Tool'
NitroPT likes this.
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
HELP: Code GTLOZER Tech & Performance Forum 5 23 Jan 2014 01:33 pm
speedometer stopped working - p0500 code shelbyzman Tech & Performance Forum 4 30 Dec 2013 03:03 am
Help with one code galeana77 Tech & Performance Forum 5 22 Mar 2013 08:27 am
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
