Hi i have a 2005 pt turbo overheating problem. We have replaced the thermostat,timing belt, cooling fan(fan assembly) and water pump and it still runs hot. My boyfriend says we should change the radiator but i dont think thats the problem. It is not loosing water either. I am out of options any help would be greatly appreciated. Thanks Marie
Why don't you just do a flush of the coolant system? You may have some blockage in the radiator or heater core. Seems like you're going about solving the problem in a haphazard and expensive way (timing belt and water pump).
![]() Aspire to inspire before you expire. |
![]() Quote:
Does the radiator fan stay on when it starts to overheat? Does the radiator fan come on automatically when you turn on the A/C with the engine cold?
If at First You Don't Succeed - Try, Try Again |
![]() Quote:
we have flushed it out several times. it was time to change the belt. The weird thing its not loosing water. Thats what has us confused we are going to have the pressure test done tomorrow. |
Pressure test the radiator cap too. The springs get weak over time and the gaskets can develop a leak too. I'd just replace it for peace of mind. And make sure you check the rubber hose running from the inlet to the overflow jug. Sometimes they'll have a crack in them and suck air in, instead of coolant.
We have tried everything even block seal and no luck s we having the head gasket replaced and having the head checked out. We did the block test and it came out fine also pressure tested the radiator. All or the test came out good so the head is the only other choice... thanks for all the tips.
![]() Quote:
Does the radiator fan stay on when it starts to overheat? Does the radiator fan come on automatically when you turn on the A/C with the engine cold? It would have been nice to have helped if some of our questions had been answered.
Thread Tools | |
Display Modes | |
2005 PT Cruiser Overheating Issues! | EnRAM | Tech & Performance Forum | 12 | 01 Aug 2016 04:54 pm |
2005 Non-Turbo Overheating Issues | SuzaMan | Tech & Performance Forum | 2 | 30 Jul 2013 09:44 am |
2005 Non-Turbo Overheating Issues | SuzaMan | General PT Cruiser Discussions | 4 | 29 Jul 2013 11:05 pm |
Overheating Pt Cruiser 2005 desiel | Sillybot | General PT Cruiser Discussions | 3 | 25 Feb 2012 01:03 pm |
2005 pt touring overheating | kudos383 | General PT Cruiser Discussions | 7 | 28 Apr 2011 04:36 pm |
