PT Just Died... Help Please!
Like Tree17Likes
Old 09 Jul 2016, 12:16 pm
Default PT Just Died... Help Please!
Hello All, So Yesterday i took off to work and less than a block away my PT just shut down. No stuttering Just dead. Turns over but wont fire. Doing the key dance shows no codes. I hear the fuel pump. I have no spark. there is no voltage to the coil pack. I checked all fuses. Anyone know where to go from here? Is there a way to test the PCM? Do all codes show up doing the key dance or do i need a code scanner? Its a 2008 base model.
Old 09 Jul 2016, 12:38 pm
Default Re: PT Just Died... Help Please!
How many miles?
Was timing belt changed?
When it turns over, does it sound as if it's turning over faster than usual?
Old 09 Jul 2016, 12:46 pm
I would suggest first removing the camshaft sensor and see if the camshaft is turning. If it is not turning then that will explain the lack of spark.
Old 09 Jul 2016, 05:30 pm
Thank you both for this bit of info.
car has 126,000 miles
Timing Belt Never Changed
And no the camshaft is not spinning!!!
Any link to how to do a Timing belt replacement?
As a seasoned vet with mechanics... Skill level to do the job?!?!
Old 09 Jul 2016, 06:39 pm
I would suggest you introduce yourself to the forum. Tell us about your PT Cruiser and how you came across this forum.
The PT Cruiser is not an easy engine to replace the timing belt. Many members here have had to take it apart several times to get the timing belt installed correctly.
You should spend some time going through the threads here on this forum on replacing the timing belt. Some of the threads have good information on how to make sure the timing belt is aligned correctly.
Old 10 Jul 2016, 01:04 am
If the cam isn't spinning at crank, yeah, the timing belt has snapped. There are excellent tutorials but this is not a job for the feint of heart. In fact, it is a royal PIA. And the timing must be perfect, if you are 1/2 tooth off, the car will run poorly.
Old 10 Jul 2016, 03:51 pm
AyeCantSeeYou's Avatar
While you're changing the timing belt, go ahead and change the water pump too. You're right there at it and it runs off the belt. May as well check the lower motor mount while you're in that area.
2002 PT LE, loaded - stock
Old 10 Jul 2016, 04:26 pm
She's absolutely right about that motor mount. It's the one in the middle with the torx head bolt that holds it in place.
rckstein and rsrocket1 like this.
Old 10 Jul 2016, 05:57 pm
I would suggest you replace the center mount when you replace the timing belt and waterpump. Some members have had to pay more money to replace the center motor mount only after putting 10 to 20 thousand miles on it.
Old 11 Jul 2016, 09:08 am
cruserdad1976's Avatar
ideler pulleys need replaced and you are already there
Key fob died War_Eagle General PT Cruiser Discussions 3 18 Apr 2016 05:58 pm
PT DIED thequadx General PT Cruiser Discussions 9 22 Oct 2012 07:50 pm
help pt died ;( oldskoolgaz Tech & Performance Forum 3 27 Dec 2011 01:56 pm
PT Died lowpt Tech & Performance Forum 8 21 Dec 2011 02:19 pm
Car just died loudassz Tech & Performance Forum 5 28 Apr 2011 06:24 pm
