ongoing clicking noise
  • 1 Post By ptcruiserinuk
Old 12 Jul 2016, 08:02 am
Default ongoing clicking noise
Clicking noise coming from in or around the near side wheel arch. Clicking starts when engine is turned on and continues when engine is turned off. I have pulled out the IOD fuse which stops the clicking until fuse is replaced. I am wondering if it has something to do with the alarm, as the alarm is not sounding when activated. Has this happened to anyone else or can anyone offer some advice?
Old 13 Jul 2016, 09:43 am
Default Re: ongoing clicking noise
sounds like a breaker may have a short somewhere. start pulling the other fuses one by one until the clicking stops. That may zero in on the problem. Also check if everything is working properly.
Mike
Old 13 Jul 2016, 03:15 pm
Thanks Mike. I'll give it a go with the other fuses. I can stop the noise if I pull out the IOD fuse, but I believe this fuse can effect different things in the car so doesn't really narrow it down. After many hours on the internet I'm 99% sure the sound is coming from the alarm siren which is housed in the near side wheel arch. I can remove the siren to stop the noise but there has to be something that is causing the siren to make the clicking and stopping the alarm sounding when it has been activated. This is where I m stuck
Old 29 Jun 2017, 03:29 am
Hi did you fix this problem as mine has started doing this today.
Many thanks
Old 29 Jun 2017, 04:10 am
rckstein's Avatar
Many thanks
Welcome to the forum
The thread you posted in is a little old, you may want to start your own thread on the issue that you're having with your PT. But first please go to Welcome New PT Cruiser Members - PT Cruiser Forum and tell us a little about yourself and your PT.
Old 29 Jun 2017, 09:00 am
Smile Re: ongoing clicking noise
Thank you
rckstein likes this.
Clicking noise from engine Simonw Welcome New PT Cruiser Members 2 31 Dec 2015 02:24 pm
Clicking Noise when braking Stephon Turbo Wheels/Suspension/Handling 1 30 Mar 2015 02:36 pm
Clicking noise from front HypnoKing General PT Cruiser Discussions 16 07 Sep 2014 04:06 pm
Ticking/Clicking noise Afitch628 Wheels, Tires, Suspension 4 28 Apr 2011 08:45 am
A/C switching noise (clicking)… ? RedPT07 General PT Cruiser Discussions 5 14 Jun 2010 09:45 pm
