It started lightly on the pass. Side and could only hear it if I drove next to a wall so the sound could echo off of it. It's starting to get a little louder and more pronounced. It was happening only in first gear when taking off. Now i get it in 2nd gear too. I've replaced everything on both sides that has to do with drive lines except the pass Side cv shaft so I'm thinking it's the cv shaft. Doesn't click if i press the clutch and coast but clicks if I start driving.
CA
THe cv shafts are not equal length are they? When i look underneath at the pass Side cv shaft it looks as if it's in 2 sections. One straight long axle connecting to a same size cv shaft as the driver side.
That is correct for your turbo PT. It's got an intermediate shaft with a carrier bearing. But most of the non-turbo PT's just have single long CV shaft on the right side.
I just bought a new intermediate and right CV shaft for my turbo convertible project. And it just came today. Here's a link: Handy's New Turbo Convertible PT Project! Also, if you go back in my project thread a bit, you will see how mine looked when failed. Based on reports on this forum and others, failure of the carrier bearing on the intermediate shaft is fairly common. Here's a link to that part of my thread: Handy's New Turbo Convertible PT Project! And here's a couple of photos of the new shaft. As you can see, the bracket is metal but the carrier bearing is mounted in molded rubber and cannot be replaced by itself: ![]() ![]()
![]() Last edited by Handy_Cruiser; 14 Jul 2016 at 11:41 pm. |
Better obtained information about intermediate shaft on PT Cruisers and or the carrier bearing based on the number of produced PT Cruiser using them is shows NOT a common part that fails with in a normal service life or as the PT Cruiser was designed to be a *100,000 mile vehicle.
![]() ![]() There are a few exception and the only one that comes to mind on a PT Cruiser is the lower control arm bushing. However most of them still fall into the high mileage or failure due to where they are driven rather then poor design. I wish some members would stop using the internet and owner posted information as your predominate source of PT Cruiser information IMHO this really make PT Cruiser in general look like a FORD=Fix And Repair Daily. If one were able to get any part supplier to tell them the sales history of a intermediate shaft or bearing you may find better answers as to how common they are sold. Or in this case how infrequently. ![]() The biggest problem with the intermediate shaft assembly is the support bracket itself and mounting. It has been shown to be of poor design and can break if the PT Cruiser is used constantly used in acceleration trails. ![]()
To view larger pictures simply "click " on the picture! Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() ![]() Last edited by NitroPT; 15 Jul 2016 at 09:00 am. |
![]() Quote:
If you have a better idea or way, by all means share it. I don't mind you shouting down anybody's theories or methods (including my own), but please don't discourage owner posted information. A perfect for instance is the DMF. If it weren't for a few people posting problems and a TSB (that didn't apply to my car) we might not have even known that our car had one, let alone that it was starting to separate and making my car impossible to shift. That doesn't mean that it is a common problem or that everybody has to run out and get solid flywheels. Same with the intake gasket on the aluminum manifold - owners mentioning it was a problem is what put me on to that as a potential problem. I think we are arguing semantics with "common problem". I don't take common problem to mean that most cars will have the problem, merely that it is not 1 in a 1,000,000 and it is an item to check. EDIT to add that your last paragraph is something I consider "owner posted information" and the kind of thing I like to know. Well, not "like" I don't actually like to hear any part is a poor design, but I would much rather know it than be ignorant of the fact.
2003 GT 5 speed 162,000 miles Last edited by Fk5; 15 Jul 2016 at 09:19 am. |
FK5 your comments may be slightly off topic so my response will be considered as well OFF TOPIC:
![]() Funny ...when a shop incorrectly diagnosis a problem and or does a less then quality repair members are all over posting about there experience but when I point out real information about procedures and part information based on records of a shop that works on average 2 PT Cruiser a month and can access sources of factual information and data it is viewed almost in the same light as those mentioned bad auto repair shops. The point is that in this thread mentioning the intermediate shaft as a part the may frequently fail is inaccurate and poorly advised. Comments condemning my responses is exactly why 99% of qualified ASE and long time experienced Auto Technicians as well service shops rarely waste there effort to help on vehicle related forums. I do this forum because I own drive and mod a PT Cruiser. Should that day ever come when I no longer own one than I will move on. This is not the first forum I have been on and I do belong to dozens that information given from a experienced member of subject matter is constantly ridiculed. I personally dont mind as long as you do not get to personal with names and stupidly try to threaten me! ![]() I have talked to a friend that has his own you tube and many friends that could contribute so much to forums and have tried to invite them into this one...they all say NOT a chance after seeing how I get into interesting debates from some members. https://www.ericthecarguy.com/ On a side note... if members carefully re-read my last response there is a clue to some great information that never seems to sink in about PT Cruisers. For those that do not know all the abbreviation used by people...DMF = Dual mass flywheel http://www.ptcruiserlinks.com/forum/...reviation.html Oh, one more thing...if members were to look and use this forum search engine you may find that I actually mentioned,pictured and talked about the intermediate shaft as well changed mine long before the other guy. Even painted mine up to look pretty "kool" before installing it. ![]() For those really thinking that they need to change it order carefully.
To view larger pictures simply "click " on the picture! Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() ![]() Last edited by NitroPT; 15 Jul 2016 at 10:12 am. Reason: http://www.ptcruiserlinks.com/forum/non-pt-discussions/46607-automotive-terms-abbreviation.html |
More OFF TOPIC ![]() Quote:
![]() ![]() I could spend the whole week on this subject alone. ![]() To name a couple that quickly comes to mind.... How about the totally outdated watts-link assembly or drum brakes on the rear of some model PT Cruisers.... ![]() ![]() but again the clue to something very important was in my response before all this defending myself started..... ![]() |
![]() Quote:
I think you are good guy, but you seem a little too worried about getting your point across. Most of us received it a long time ago. That doesn't mean we should stop posting. I also don't know what you were defending yourself from. Literally the only thing I said was that I believe owner posted information is useful. If you disagree with that, I understand, but if that is the case, we will have to agree to disagree. EDIT: to state that I can't see the video here, so I have no idea of how it relates.
2003 GT 5 speed 162,000 miles |
Thread Tools | |
Display Modes | |
Clicking noise from engine | Simonw | Welcome New PT Cruiser Members | 2 | 31 Dec 2015 02:24 pm |
Clicking Noise when braking | Stephon | Turbo Wheels/Suspension/Handling | 1 | 30 Mar 2015 02:36 pm |
Clicking noise from front | HypnoKing | General PT Cruiser Discussions | 16 | 07 Sep 2014 04:06 pm |
Ticking/Clicking noise | Afitch628 | Wheels, Tires, Suspension | 4 | 28 Apr 2011 08:45 am |
A/C switching noise (clicking)… ? | RedPT07 | General PT Cruiser Discussions | 5 | 14 Jun 2010 09:45 pm |
