A/c issues
  • 1 Post By NightWing
Old 16 Jul 2016, 03:21 pm
Default A/c issues
I haven't had a/c for a while, but haven't worried about it because I didn't need to go very far, but I'm about to take a new job that will require me to drive a lot. So here's the problem and what I've done.
My a/c blows hot air which led me to look up what the problem might be. I discovered that it was likely a lack of refrigerant. So I purchased a can with a guage and followed the instructions.I turned my 2007 pt cruiser on and turned on the a/c to max. I then observed my compressor to make sure it was turning, but it wasn't. So I looked that up and saw somewhere that if it didn't have refrigerant it would need some added before the compressor would turn on.
So I added some refrigerant, but the compressor wouldn't spin until it was in the yellow section of the guage. I have since discovered that I have a leak and have considered picking up a can of a/c pro super seal to close up the leak. Should I do this and add more refrigerant, or is there something wrong with my compressor? Will I even know if something is wrong if I don't fix the leak? Can anyone explain why the compressor won't spin until it has refrigerant in it, I sincerely don't understand.
Old 16 Jul 2016, 03:42 pm
Talking Re: A/c issues
The refrigerant contains a compressor lubricant. Running the compressor dry can burn it up.
Old 16 Jul 2016, 03:49 pm
Default Re: A/c issues
I assume this is why it won't spin without the refrigerant. Should I then go ahead and try to seal the leak and then try to add more refrigerant?
Old 16 Jul 2016, 03:57 pm
Do you know where your leak is? AC repair shops add a dye to the charge so they can see any leaks. I have read that stop leak in radiators is a no-no because it can plug the tubes. I would guess that a similar product in an AC system might not be the best course of repair.
If your system has been dormant for a long time, it should probably be evacuated and have the receiver-dryer replaced. Rather than dink around, your best bet might be an AC repair shop that knows what they are doing.
Have a few issues if I can get some help... pickup1 Tech & Performance Forum 5 02 May 2015 07:47 am
MORE A/C issues SRT8guy Tech & Performance Forum 2 11 Jul 2012 10:50 pm
PT issues Popcorn1 General PT Cruiser Discussions 4 18 Jul 2011 09:31 am
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
2 Issues - Need Help 07PTSilver General PT Cruiser Discussions 2 09 Dec 2008 03:45 pm
