Indicator beeps when indicating.
Old 17 Jul 2016, 01:47 pm
Default Indicator beeps when indicating.
Hi all.
Last post from me. When my cruiser is wet, rain or car wash, until it dries, everytime I use my right indicator there is a beeping/buzzing sound, in time with the normal indicator sound.
Sounds like it's coming from the rear indicator.
Any advice on how to fix it?
Lights work fine, I'm kinda thinking a leak getting into the circuit of the indicator, but not sure if there is a common area this happens.
Many thanks.
Old 19 Jul 2016, 11:37 am
JonN's Avatar
Default Re: Indicator beeps when indicating.
The same thing happened to me yesterday! Was on the highway and about to get off an exit, put my right blinker on and a beeping noise started. I looked at my cluster and saw no lights and was left confused.
Sorry I don't have an answer to why that has happened, but I figured I'd let you know you are not alone with this issue.
Old 19 Jul 2016, 11:54 am
Maybe try replacing the flasher? IDK
Old 20 Jul 2016, 09:24 am
I'm finding out the hard way there is no trouble shooting this without a scanner. The best you can do is open all the connectors and look for corrosion. All the strange electrical problems on the pt and jeep have been water in a connector.
My PT is at the body shop now to find where the water is coming from as I just got it back from the dealer that found water in a connector under my dash was causing all kinds of issues.
Good luck!
mike
Low Fuel Indicator Light bmeador55 Interior Accessories Forum 7 10 May 2014 10:45 pm
Oil pressure indicator muttonjavelin General Turbo Discussions 6 08 Aug 2012 04:06 pm
Shift Indicator GinPa General PT Cruiser Discussions 9 29 Nov 2011 05:34 pm
engine light accelerating the pt beeps everytime? PTCHANDLER General PT Cruiser Discussions 5 08 Dec 2010 01:21 pm
indicator and hazard lights jobaz General PT Cruiser Discussions 4 24 May 2010 12:28 pm
