Need help to trace ABS DTC ( 20)
Old 18 Jul 2016, 12:19 am
Default Need help to trace ABS DTC ( 20)
Hi, I would like some info on this code. code number 20 its in the abs system codes, It says Pump circuit failure, Where would I find info on how to trace it? Thanks
The ABS and TRAC lights are on and I am using a snap on scanner to access the system. Code wont clear most of the time, but if it does it turns back on in 500 ft of driving.
Old 18 Jul 2016, 12:50 am
Default Re: Need help to trace ABS DTC ( 20)
Welcome to the forum.
Did you try resetting the code to see if it comes back?
Old 18 Jul 2016, 11:30 am
Hi, Thanks for the welcome. I have reset the code, but it come back as soon as I drive a few hundred feet. The scanner I use shows the wheel speed sensor and shows the actual speed when driving. they all work. Its something in the wiring but not sure which and where to look.
