2 questions on my PT
  • 1 Post By CREWZIN
Old 18 Jul 2016, 10:55 am
Default 2 questions on my PT
2006 PT base 4 cyl. 5-speed: I am suffering from a low clutch release, hard to put in gear etc... I have spaced the slave cylinder which helps but did not totally cure...HELP
I also have a code P0132 02 Circuit Hi Voltage (bank 1, sensor 1) any help as to which & where would be appreciated.
Car runs fine but sends this code once in a while then disappears???
Thanks for any ideas............
Old 18 Jul 2016, 03:39 pm
Default Re: 2 questions on my PT
No help on the clutch but the code says there's a problem with the upstream 02 sensor. Should probably change both upstream and downstream sensors.
Teekypt likes this.
Old 18 Jul 2016, 05:18 pm
You may have warm out shifter bushings. Look under the air cleaner box see if they are sloppy. I stuck a slice of rubber hose in mine until I could buy some replacements.
Questions about my car Slowrider Tech & Performance Forum 7 30 Jul 2014 07:43 pm
2 more questions..noobe questions.. BarbieCar General Turbo Discussions 9 20 May 2012 07:32 pm
Two Questions FanDroid General PT Cruiser Discussions 4 18 Nov 2011 09:06 am
New-to-me and Questions pp6000v2 Tech & Performance Forum 1 28 Jul 2010 03:42 pm
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
