No Fuse + No DRL error
Like Tree7Likes
Old 24 Jul 2016, 10:57 pm
Default No Fuse + No DRL error
Hello Everyone I just joined after reading the threads here for days. I am really finding the PT Cruiser community a thing of beauty
I have a 2001 Pt Cruiser with 108000Km just inherited by a death in the family and getting it ready for my daughter to use as her first car.
Problem is the IPC shows NO FUSE - NO DRL
Other symptoms are
- Dome lights not working
- Radio not working
- Side Mirrors adjustment Do not work
- Trip odometer not keeping memory.
- DRL lights not working
However..
- Door locks work fine both interior and remote buttons
- Starts and Drives fine
- No other abnormal lights on IPC
- No check engine
- No ODBII error codes
- headlights, taillights, flashers all working fine
What I have Tested
- I have pulled and tested
- IOD fuse (15amp) under the hood. (tested ok, changed anyways)
- All remaining Fuses (all tested ok no blown fuse found)
- Radio is getting +12v on pink/red wire with key
- Radio is not getting +12v on Yellow (memory)
- Radio works fine if I hook the memory pin to +12v
- Dome lights not getting +12v at dome switch
- Pulled the batter for 1hr
From what I have read that if my IOD fuse is not blown its could be the IPC or the BCM or a ground fault. I find it gets confusing here is the BCM integrated into the IPC or separate?
Can I just replace the IPC from a scrapped PT?
Anyone have a tip How I can test this further?
Thanks in advance
LW
Old 24 Jul 2016, 11:20 pm
Default Re: No Fuse + No DRL error
Welcome to the forum.
Old 25 Jul 2016, 03:27 pm
Thanks.. So much info here I am loving the love for the Pt
Old 25 Jul 2016, 04:42 pm
Other symptoms are
- Radio not working
However..
- No check engine
What I have Tested
Thanks in advance
LW
Have you checked to make sure all fuses have voltage going to each one?
LinuxWookie likes this.
Old 25 Jul 2016, 05:55 pm
Because Trump
Old 26 Jul 2016, 08:51 am
Yes there is voltage at the IOD fuse..
there is voltage at the int Fuse #13 as well
Both fuses are tested working.
Old 26 Jul 2016, 08:54 am
Originally Posted by sanatanadharma View Post
There are two fuses in series that protect the circuits for the dome light, the power mirror switch, radio and instrument cluster.
The under-hood PDC fuse #18 (20 amp) and the dash fuse #13 (10 amp)
Under the hood is a #18 not the #17 IOD fuse you mean?
I testee #18 as good as well.. THe #13 is also good as well. I am starting to thing its the IPC/BCM?
Old 26 Jul 2016, 09:40 am
From the 2003 PT Cruiser shop manual wiring diagrams:
Fuse #13, 10 amp, protects these circuits;
sentry key immobilizer (chipped ignition key)
remote keyless entry
power mirror switch
cargo lamp
dome lamp
overhead console
instrument cluster (low fuel, low oil, low battery lights)
visor mirror lamps
Old 26 Jul 2016, 10:05 am
power mirror switch
cargo lamp
dome lamp
overhead console
visor mirror lamps
Yeah #13 is good Tested with a meter.
And not all those systems are out. The overhead console is working, the remote key is working the car runs and drives fine so I will assume the Sentry Key is working as well. The Cluster lights all seem to be working as well.. minus the trip odo. that resets to zero each start.
From what I can see online it looks like it could be a bad ground or ipc/bcm?
is the bcm integrated into the ipc? I was thinking of going to KennyUPULL and just grabbing another IPC.
Old 26 Jul 2016, 11:18 am
Because Trump
no Fuse problem and not iod fuse ptcarter Tech & Performance Forum 24 09 Jul 2013 03:21 am
Rigged Fuse Blew and Shot a P1681 error, Car in Limp mode matthewmilbut Tech & Performance Forum 6 28 Jun 2012 12:31 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
HELP with Wiring Fuse 7 (No feed to fuse) No A/C, Electric Windows, Rear fogger??? ptcruisershoreham General PT Cruiser Discussions 3 08 Mar 2011 08:06 pm
new radio no power + error code " no fuse " ? Ctown Sound and Security Forum 4 22 Apr 2006 06:03 pm
