Air Conditioniong Temps...
Old 27 Jul 2016, 01:21 pm
Default Air Conditioniong Temps...
So no matter what speed the fan is set to or the outside temp the air never gets colder than 50 degrees at the vent. Have played with the charge a bit and it has no effect. Seems it starts to cool and then it cycles off.
Any ideas?
2006. 2.4 Vin Code "B".
Old 27 Jul 2016, 01:37 pm
Default Re: Air Conditioniong Temps...
If you have to high a pressure or to low the system will shut off. Does it do the same thing while driving along the highway at a steady speed?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 27 Jul 2016, 01:56 pm
Talking Re: Air Conditioniong Temps...
Where are you located? A/C temp differential is related to ambient temperature. Are you using recirc or open setting? Recirc will give the coldest performance.
Old 27 Jul 2016, 07:56 pm
At an ambient temp of 92 with the air set to recirc and max, system psi is 55/250.
Driving at highway produces same results.
PT cooling fan actuating temps 04 PT Jgriff Tech & Performance Forum 4 24 Aug 2014 06:27 pm
Below Zero Temps and Unable to Start talexander General PT Cruiser Discussions 16 09 Dec 2013 08:03 pm
At what temps does the fan come on? JenneK Tech & Performance Forum 13 10 Jul 2012 11:04 pm
NEW OEM Coolant Temps Sensors UptownSport Classifieds: For Sale/Trade 0 23 Oct 2011 12:27 pm
Air box temps blucruzer Tech & Performance Forum 2 28 Apr 2009 11:33 am
