01' Won't hold COOLANT
Like Tree6Likes
Old 02 Aug 2016, 08:55 am
Default 01' Won't hold COOLANT
Yesterday after driving home in hot weather I noticed the temp gauge climbing to 3qtr up so I popped the hood and looked in coolant tank it was empty so I poured qtr jug of coolant in and that was all I had so I put water in shut it off took another car to the advance auto and picked up some more coolant ...when I came back I noticed the water level in coolant tank hadn't one down much so I ran the car for 7min with heat on blast and couldn't get it to overheat but the coolant tank was losing water so I start pouring antifreeze coolant in and it takes the whole jug and it comes pouring out the bottom, so she's not holding her coolant so I dropped it off at Midas this morning since they are only a mile away...waiting to hear what the deal is
Old 02 Aug 2016, 09:09 am
Default Re: 01' Won't hold COOLANT
Sounds like it might be a leaky radiator or a leaky radiator hose.
Keep us posted on what you find out.
Old 02 Aug 2016, 09:55 am
Midas? Many, you're going to get a call saying you need a whole new exhaust system and four wheel brake job! LOL It sounds to me like your overflow jug has a hole in it or the hose came off. Good luck with Midas.
Old 02 Aug 2016, 09:45 pm
Agree.
MANY, MANY years ago I went to Midas for an exhaust. Kid was using a torch to heat up joint where new system was going to join old system - I didn't like the heating up, because that part will then rust much faster. Anyway, undercoating started to catch fire and kid was slapping at flames with an oily rag, and I saw brake and gas lines in exhaust tunnel - I told them to get my car off the lift immediately - I left and haven't gone to Midas since.
Old 03 Aug 2016, 01:57 pm
Fk5 Fk5 is offline
When you say coolant tank, you mean the overflow/recovery? They will only take so much water before they start spitting it out the overflow. Sounds like you ran low for whatever reason and then tried to overfill it. Do a pressure test and find the leak. Midas will probably handle that.
2003 GT 5 speed
162,000 miles
Old 03 Aug 2016, 03:18 pm
It was posted that he poured a jug of coolant in it and it started pouring out the bottom?
Old 03 Aug 2016, 05:00 pm
Fk5 Fk5 is offline
Yes. That is what I read
2003 GT 5 speed
162,000 miles
Old 03 Aug 2016, 05:33 pm
I was just trying to say that if its pouring out the bottom you might be able to physically see where the leak is coming from.
Old 03 Aug 2016, 05:38 pm
Fk5 Fk5 is offline
My point was that when you overfill the reservoir it will pour out the bottom. That is what I think was happening.
rob302 likes this.
2003 GT 5 speed
162,000 miles
Old 03 Aug 2016, 06:01 pm
rob302's Avatar
Originally Posted by quicksilverdon View Post
Agree.
MANY, MANY years ago I went to Midas..........Kid was using a torch to...........Anyway, undercoating started to catch fire and kid was slapping at flames with an oily rag, and I saw brake and gas lines in exhaust tunnel - I told them to get my car off the lift immediately - I left and haven't gone to Midas since.
i sometimes do stuff like that just to mess with people.. it's actually quite fun to catch the PT on fire with a torch. great stress relief.
torching the PT
i'd bet on the overflow simply being overfilled and running out the stupid overflow tube that you can't see. chrysler must have been laughing when they designed it. like "hey lets make it so instead of coming out the cap, it runs out a hidden tube onto the hot exhaust manifold and makes a huge steam cloud"
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Will the tranny hold? HighOutputSRT4 General Turbo Discussions 15 11 Feb 2013 08:59 pm
Here's why Pepe's on hold TurboDucky Members PT Project 26 04 May 2012 01:50 pm
...all Chrysler pcm's on hold???? earringboy Turbo Performance 28 20 Sep 2003 11:55 am
HOW MUCH BOOST CAN WE HOLD?? COP TZER Turbo Performance 11 16 Jul 2003 02:11 am
