Shifting Problems
Like Tree3Likes
  • 1 Post By Gotsea
  • 1 Post By Gotsea
  • 1 Post By NitroPT
Old 03 Aug 2016, 02:56 pm
Default Shifting Problems
Hi guys, this is my wife 2006 PT cruiser automatic transmission (none turbo) it is driving me crazy, it is getting stuck in first gear the way she dealing with it is by turning it on and of several times till it finally start shifting, she also says that the gear indicator in the dash illuminates all the gears indicators at the same time, I have put a new battery, new computer, new transmission solenoid to no avail, any comments suggestions are well com, thanks
Old 03 Aug 2016, 03:45 pm
Handy_Cruiser's Avatar
Default Re: Shifting Problems
Could be in the instrument cluster which also serves as a body control module. Or it could be in the shift selector switch in the transmission. And there's several additional "or's".
This is one of the those few times that I recommend taking a car to a shop. A good transmission shop can do diagnostics that you cannot do at home. You just have to find a good shop that doesn't tell every customer that comes through the door that they need their transmission rebuilt.
Also, if your 2006 has the VLP transmission, I have a low-mileage unit I'd love to sell.
Old 05 Aug 2016, 10:39 am
New development this morning when my wife was going to leave for work the car did not want to shift, I open the hood and gently moved the wire harness coming from the computer and the car die, started again and again die when I move the harness, stared and then start shifting but the spedo does not work now I will get in there over the weekend , any ideas will be appreciated, thanks
Handy_Cruiser likes this.
Old 05 Aug 2016, 11:32 am
This is actually good news. You may only be dealing with a bad PCM plug or harness.
I would remove all the plugs from the PCM (computer). And would inspect them very closely. If I saw no issue I would clean them and the sockets on the PCM very thoroughly with electrical cleaner. If I found oil in one or more of the plugs, I would replace the oil pressure sending unit which can push oil up through the wire loom if leaking. Then I would reassemble and see what happens.
If no joy, I would pull the connections again, remove the wire loom and tape and inspect again looking for broken wires and/or damaged insulation.
Also, be sure to inspect the PCM sockets for bent or corroded pins. I believe the plug that controls the transmission is the one marked in green.
Old 05 Aug 2016, 05:12 pm
Thanks, handy I will look in to it and let you know
Old 06 Aug 2016, 10:07 am
I would be surprised if it was stuck in 1st. More likely second as that is the default for a TCM problem. I would serious take your PT Cruiser to a transmission shop and have them check the TCM codes.
chuzz likes this.
Old 06 Aug 2016, 01:10 pm
I don't think Todd mentioned disconnecting the battery before messing with the PCM. At least, that's what I'd do, but I'm NOT a mechanic. I don't know diddly squat. NitroPT has always given me good advice. You may want to do as he suggested.
Shifting Problems. Trentwood Tech & Performance Forum 0 31 May 2016 07:48 pm
shifting problems matrixrk Tech & Performance Forum 1 11 Jan 2016 08:00 am
Shifting Problems YOLO Tech & Performance Forum 2 10 Jan 2013 12:46 pm
New here, Bad Shifting Problems need help mko General PT Cruiser Discussions 10 11 May 2009 10:06 pm
SHIFTING PROBLEMS VinnieG Tech & Performance Forum 1 04 Oct 2008 09:42 pm
