Adventures of the P0481 kind
Like Tree3Likes
  • 3 Post By 944tim
Old 07 Aug 2016, 01:39 am
Default Adventures of the P0481 kind
bought an 06 TE. When I bought it it had loose wires run from a switch on the driver's door to the fan relays.
A CEL code PO481. PO told me: ran hot, rebuilt head, new head gasket, water pump, still ran hot. took to dealer and they said 'computer bad, 2600$. PO says XXXXXX and hotwired the fan. Fan burned out, PO added a replacement fan assy. Drove it for a year with the hotwires in place, sold it to me. fan died that week.
I start at the fan. Bad, replace fan, pulled fanmotor apart, brushes bad. OK. Now checking wires from power and computer. Erratic readings. 3.7 v 3.4v, etc.
CEL says dOnE
Send of for recoded computer, 169$ on ebay, I have used these guys before with no problems. Install computer. Nothing new, still doesn't work. sXXt!
Track hot and control feeds to fan. Not getting continuity between body GROUND and Battery ground Clean and polish main ground stud on bulkhead, dielectric grease, the works. Still no GROUND at fan. Build direct ground from batt terminal to fan. proper joints, soldered and heat shrink, correct terminals etc. OK good ground to fan, to body, good all around. Getting good at pulling and reinstalling fan,, etc.
Control legs to fan are correct voltage, as far as I can tell. Voltage to hot leg of fan, 3.7v. huh.. Go back to fuse panel. Good there, current should be getting through. Hotwire to check fan and it works on cue. ok. find a 50 amp fuse and socket, built a whip direct from +post of battery to fan harness. 12V. Plug everything in, and fan kicks on . since then, never exceeds 1/2 of temp gauge, even in traffic and AC on. All new wiring has proper soldered and crimped fittings, heatshrink and wire tied in place, Success! Also CEL went out, and pulls no codes.The fault is somewhere in the wiring harness, a broken connection, a bit of corrosion, I dunno.
tl:dr before you spend too much fixing the PO481 code, check your wiring harness, grounds and actual voltage output.
Old 07 Aug 2016, 07:05 am
rckstein's Avatar
Default Re: Adventures of the P0481 kind
Welcome to the forum
Sounds like you've had quite the adventure already with your PT. Please post some pics of it when you get a chance.
Old 07 Aug 2016, 08:01 am
CEL says dOnE
The constant cycling of the fan either lo or and high speed causes higher AMP draw and probably higher amp draw as it comes to end of life for the brushes causing heat, and if the harness connector pins are just a little loose lots of heat buildup melting the connector and loosening the connector pins even more until they fail. A new fan is installed and the unsuspected connector causes confusion because now the new fan doesn't work . Glad you found the problem...
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 07 Aug 2016, 08:19 am
Welcome to the formun, Tim. Nice job and write up on your repair.
Old 07 Aug 2016, 11:02 am
I posted this because I was looking all over for info and the most useful came from these forums, so payback, anything I can learn and share is help for someone else.
rckstein, Fk5 and chuzz like this.
Tags
fan controls, overheating problems, p0481
2008 PT Cruiser AC Adventures shortattentionspan Tech & Performance Forum 3 03 Jan 2015 05:13 pm
Rad fan P0481 VNT General PT Cruiser Discussions 11 09 Jan 2014 03:25 am
Code P0481 came on jcmnz24 General PT Cruiser Discussions 5 28 Sep 2013 08:56 pm
help! p0481 Crid General PT Cruiser Discussions 1 19 May 2012 01:19 pm
P0481!!!!! CruiserNewbie Tech & Performance Forum 3 23 Feb 2012 09:12 am
