AC High Pressure On The Low Pressure Side?
Old 07 Aug 2016, 02:07 pm
Default AC High Pressure On The Low Pressure Side?
2006 PT non-turbo.
My AC is barely working, blows a little cold but not much.
When I check the the pressure on the low side it is reading 70 psi.
I believe it is supposed to be somewhere around 30-38 psi.
My rad fan is working correctly and so are the relays.
As well I checked the low pressure switch on the accumulator and it is working too.
Anyone one have any idea what could be causing this?
Any input is always greatly appreciated.
Thanks.
Old 07 Aug 2016, 09:45 pm
Default Re: AC High Pressure On The Low Pressure Side?
Found the problem. Thanks.
See here:
Replacing a female connector in a relay junction box
how do you remove the ac high side pressure switch? notw_nml Tech & Performance Forum 2 15 Aug 2014 08:36 am
Fan speed when a/c on? And a/c pressure going high RacerX125 General PT Cruiser Discussions 4 09 Jun 2014 03:39 pm
A/C High Pressure cut-out Switch myanez Tech & Performance Forum 2 03 Oct 2011 09:59 pm
A/C high pressure hose r&r PtBrewzer Tech & Performance Forum 1 24 Jul 2011 12:52 pm
High Side Pressure switch smithcruiser General PT Cruiser Discussions 4 08 Aug 2009 08:24 am
