No Right Turn Signal, Low Beam or Horn
Like Tree4Likes
Old 07 Aug 2016, 05:59 pm
Default No Right Turn Signal, Low Beam or Horn
First post and really need help! 2007 Limited, on right side only (passenger) no low beam, no turn signal and no horn. All fuses are good and I even replaced the entire distribution box as I was told by Chrysler, "that is the problem". Didn't change a thing. Inspection due so I'm hoping for something simple.
Old 07 Aug 2016, 06:12 pm
rckstein's Avatar
Default Re: No Right Turn Signal, Low Beam or Horn
Welcome to the forum
Did a shop do a diagnosis on your PT, or were they just going off what you were describing the problem? You replaced the TIPM? And if so, with a new or remanufactured one, and from where did you purchase it from?
Old 07 Aug 2016, 06:35 pm
I called the local dealer, service department, and that is what he said. I went to a salvage yard and took one out (rear end wreaked). Everything else works the way it should.
Old 07 Aug 2016, 06:41 pm
rckstein's Avatar
There is some information that some dealership programming may be required after replacement of the TIPM. That may be one reason why they charge so much for that repair.
Old 07 Aug 2016, 06:47 pm
Check your wiring.
I just had an ABS light (and TRAC and Brake) come on, and I figured it was an ABS sensor and I don't have a reader to tell me which one, so I brought it to mechanic - some critter had chewed into the wiring harness! I learned it's fairly common.
Old 07 Aug 2016, 06:53 pm
UGH! I was thinking about changing the MULTIFUNCTION SWITCH next but was hoping someone else may have had this problem.
Old 07 Aug 2016, 08:18 pm
rckstein's Avatar
There's also no way to determine if the TIPM you got from the salvage vehicle was good.
LionPT likes this.
Old 07 Aug 2016, 10:19 pm
LionPT's Avatar
^^^ This
Also check your ground wires.
There are no fuse/relays for the problems you are having.
Check the 2 on the drivers fender once air box is removed.
bob2006, rckstein and JoeX like this.
Old 08 Aug 2016, 08:27 am
Try resetting the TIPM yourself by disconnecting both battery cables and holding them together where the clamps make contact for fifteen minutes. Just use a c clamp or some vise grips to do that. Unless you want to zip tie or use a string or rubber band or something. SUPPOSEDLY, this will reset the TIPM. I don't know personally, as the only vehicle I ever had with the TIPM got killed at only 65,000 miles (2008 Caliber) and the one in my 2013 200 hasn't given me any problems.
Old 08 Aug 2016, 09:29 am
From what I understand the TIPM can only be reset by the dealer. There might be a few repair shops that might have it the device but its very expensive and most repair shops just replace them to see if it fixes the problem. Some members have even complained about the dealers installing faulty TIPM's in their PT Cruisers.
Front Turn Signal Lights Turn On and Off When Applying Brake? Danny7627 Tech & Performance Forum 12 20 Jan 2014 09:42 pm
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
Turn signal / high beam / fog light stem 2BadRic Exterior Accessories Forum 2 21 Mar 2013 10:24 am
Turn signal activates signal...and wipers? TF3 General PT Cruiser Discussions 2 19 Feb 2013 12:48 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
