Is there a guide to undoing wiring connectors?
Like Tree4Likes
  • 2 Post By CREWZIN
  • 2 Post By bob2006
Old 07 Aug 2016, 08:21 pm
Default Is there a guide to undoing wiring connectors?
I think I found the problem with my ac.
A frayed wire on one of the radiator relays.
I have to disconnect both relays from the bottom of the radiator.
Anyone know how these connectors disengage?
I don't want to damage them by forcing things.
Thanks for any help
Old 07 Aug 2016, 08:23 pm
Default Re: Is there a guide to undoing wiring connectors?
The one with the pink/red clip, slide the clip to one side, unlocking the connector and find a small tab that has to be pushed down while sliding the connection apart.
The other without the slide tab should have a small tab that pushes down as you pull the connection apart.
rckstein and VsandFords like this.
Old 07 Aug 2016, 08:29 pm
Thanks for the reply.
Going to try it now.
Old 07 Aug 2016, 08:36 pm
I got the bigger grey one to disconnect!
On the red one do you know which way i should slide it?
I tried both ways but there is really no movement either way.
Do I have to push a tab somewhere in order to get it to slide?
Thanks for your help. Much appreciated.
Old 07 Aug 2016, 09:36 pm
Got the second connector disengaged.
I could not get any leverage on it with my big fingers so I took a small, thin bladed screw driver and pushed it between the the black plastic and the solid red of the connector getting it to slid to one side and that did the trick.
Here is a pic of the open connector.
You can see that it slid out about 3/8 of an inch.
Thanks for your help again CREWZIN
Old 07 Aug 2016, 09:41 pm
Glad you got it.
Heated seat wiring connectors iBorg Classifieds: Want To Buy 0 10 Dec 2013 08:21 pm
Electrical Connectors to PCM Mizzou General PT Cruiser Discussions 2 08 Oct 2013 08:39 pm
Ignition wires, use HEI Connectors? logonsys Tech & Performance Forum 13 08 Nov 2010 12:55 am
I need a stereo wiring guide for an 02' thatsmrjptou Sound and Security Forum 1 14 Apr 2009 08:27 pm
Coupler Connectors DaShado General PT Cruiser Discussions 2 28 Dec 2008 11:03 pm
