Replacing a female connector in a relay junction box
Like Tree3Likes
  • 2 Post By bob2006
  • 1 Post By bob2006
Old 07 Aug 2016, 09:53 pm
Default Replacing a female connector in a relay junction box
I found the problem with my AC.
It was a broken wire leading into the relay junction box.
The wire is too short to strip and repair so I need to solder a new length of wire on to the female connector.
Does anyone know how to remove the female connector from the junction box?
It is loose and wiggles around but I can't seem to get it to release.
Any input is always appreciated
Here is a pic of the part.
Old 08 Aug 2016, 08:31 am
Default Re: Replacing a female connector in a relay junction box
I'm not sure man, but it looks like you MIGHT be able to stick a small flat head screwdriver inside each socket and release the wire. Then you could pull them all up and just clip and repair the bad one? IDK, I'm not a mechanic. Just guessing by looking.
Old 08 Aug 2016, 02:26 pm
Thanks for the reply
That is exactly what I did, except I used the flat side of a small cotter pin. I pushed the lock tab down from the back of the connector and then from the center of the connector. The connector is then removed up through the box.
I just finished the job now.
I soldered new wire on to the connector and used heat shrink to make it tight.
The connector pops back into the box easy and secure.
I reinstalled the wiring and now my rad fan comes on and stays on, on low speed when the AC is switched on.
Unfortunately I still have no cold air blowing.
Going to keep at.
Thanks to all who helped out.
This forum is the best.
Old 08 Aug 2016, 02:34 pm
Congrats on the fix. Sorry to hear you still don't have a/c. Are you sure that you have a full charge in it? Mine gets so cold, that I sometimes have to turn it up. If I don't my glasses steam up as soon as I stop the car and get out. And my wife constantly complains that it's too cold. She closes her vents and I raise the temp as a compromise.
Old 08 Aug 2016, 07:57 pm
Got it working.
See here:
AC working with another question
rckstein likes this.
Female non-blond YJZSGRAYPT Tech & Performance Forum 5 05 Nov 2015 08:26 am
HELP! Female-not BLOND! YJZSGRAYPT Tech & Performance Forum 7 02 Oct 2015 09:55 pm
Replacing a Radiator Fan Relay in a 2008 PT Cruiser. RMThompson Tech & Performance Forum 5 11 Aug 2012 09:39 pm
Replacing a Radiator Fan Relay in a 2008 PT Cruiser. feihong Tech & Performance Forum 1 01 Feb 2012 06:25 am
