Indicators flashing. Why?
Old 08 Aug 2016, 12:47 am
Default Indicators flashing. Why?
Just tonight, I experienced something - in our 2009 PT Cruiser - that my wife had shared with me, a few days back. I had just left a grocery store, and thought that our car was a bit sluggish on starting. Driving home, I noticed that the icon notices - which would light up at the bottom of the speedometer window - began flashing on & off, and continued that way until the car was turned off, upon my return home.
What might this be due to?
God Bless,
Nathan
(2009 PT/ non turbo/auto)
Old 08 Aug 2016, 01:47 am
Default Re: Indicators flashing. Why?
First I would suggest if you have a trip counter button on the instrument cluster, you can try to reset the cluster and see if this helps. If you turn on the ignition with the button held down. Try holding it for at least 5 seconds or until something starts to happen, it should put the cluster into its 'self-test' mode. All of the gauges will sweep through their scales and all lights on the cluster will be tested. This should have the effect of resetting the cluster. If it won't go into test mode or dies partway through, you would need to check to see if the instrument cluster is working properly.
If the instrument cluster is good I would you check the ignition actuator. Do you keep a few keys on your key ring?
If the ignition actuator is working properly I would suggest checking all wires going to the TIPM. The TIPM is common for being faulty. The TIPM is sensitive to voltage drops so i would suggest doing a battery load test before checking out the TIPM.
Old 08 Aug 2016, 04:05 am
LionPT's Avatar
Are you talking about the CEL (the little orange motor)..??
or are all the lights lighting up (red lights)..??
INDICATORS TURN SIGNALS HAZARDS PATGAS Tech & Performance Forum 9 29 Oct 2013 04:59 pm
indicators and wipers BogleLodge Tech & Performance Forum 3 28 Dec 2012 03:36 pm
New Multifunction Switch but still no indicators/hazards. Please help! vard3n General PT Cruiser Discussions 4 28 Aug 2009 12:08 pm
flashing skeeter1620 Turbo Performance 3 17 Jan 2004 03:14 pm
