Dumbfounded and confused
Like Tree16Likes
Old 08 Aug 2016, 01:59 pm
AyeCantSeeYou's Avatar
Default Dumbfounded and confused
How can a rod bearing be bad if there is no engine knock? Don't they always make a sound when bad? My PT never had a knocking sound. I'm still reeling from the phone call this morning from the shop my PT is at that after 4 weeks being in there and $1100 later in parts and labor, I need a new engine.
2002 PT LE, loaded - stock
Old 08 Aug 2016, 02:08 pm
Default Re: Dumbfounded and confused
If they used an audio scope the noise of a bad engine bearing may have been detected.
You could have failing engine bearing(s) present, no noise unless under a load.
There are lots more examples....
I would recommend to ask how they determined it to be a bad bearing.
chuzz likes this.
Old 08 Aug 2016, 02:37 pm
I agree with NitroPT. They might be trying to take advantage of the fact that you're a female and they think you can be easily fooled.
Old 08 Aug 2016, 03:31 pm
On one of my previous cars I had a rod knock and put STP in it. After driving it for 50,000 miles with STP I got rid of the car and never touched the engine. But as other members posted get another opinion and confirm you really have a rod knock.
Old 08 Aug 2016, 03:44 pm
Mechanic said the lower bearings are shot and aren't pulling oil like they should be, that the 'old' oil pump had low pressure and wasn't able to keep up. I asked if there was any detectable engine noise, he said no. He said they didn't know it was the bearings until they pulled the oil pan off and visually saw it. They just did that this morning! I'm just completely shocked that after telling me my car wouldn't need anything else after replacing the oil pump and the belt/pulleys for the pistons that I get this phone call. I called back and told them that I don't feel like I should have to pay for the labor to install another motor after they've had my car up there for the past 4 weeks and just now realized, $1100 later, that the engine is shot.
My PT never ran low on oil either. I always kept it changed and checked.
Old 08 Aug 2016, 03:59 pm
Handy_Cruiser's Avatar
This all sounds very fishy. Very few on this forum have reported the issues you seem to be having with your PT engine. It's sounds like you could well be the victim of dishonest mechanics.
Here's my opinion for what it's worth. Let's say your oil pressure issue really was the oil pump and not just a bad sending unit which is much more likely. A good and intelligent mechanic would have likely told you at that point that your 2002 PT is only worth so much and if that didn't fix it, it would likely be time for another car. There's no reason to run the shop bill up further.
But for them to spend $1,100 on a car likely not worth more that $2,000, they do not seem to have your best interest at heart. And that's still assuming your oil pump and now rod and main bearings are bad. Shame on those guys.
Salvage non-turbo engines are only $250 where I live. And they may be similarly priced where you live. If me, I would weigh any further repairs against the cost of a salvage engine and the value of the cars itself. And whatever future mechanic work I decide I needed, it would be at another shop.
cruserdad1976 likes this.
Old 08 Aug 2016, 04:29 pm
What parts did they replace?
What brand oil pump did they put in the engine?
Has your oil light ever come on?
Have you had the PT Cruiser for a long time?
Old 08 Aug 2016, 04:51 pm
This is where I would like to see the actual estimate and work order!
There are a few unusual descriptive comments....
I would say to those that are actually a bit more auto mechanical experienced re-read post # 5 again before making more assumptions?
Old 08 Aug 2016, 04:56 pm
It has 140,000 miles on it, give or take 1,000.
I've had it for 10 years.
6 weeks ago I had the front suspension replaced (tie rods, wheel bearings, etc) for around 900.
2 weeks after that, it was back to the shop because the oil light started coming on when I'd put my foot on the brake pedal. Did some research and found the usual cause was the oil pressure sending unit, which I went and got from auto zone and had the shop replace while I was there. Before this, though, last winter, when the temp would go below freezing, the oil light would come on, then go off when the outside temp went above freezing. Didn't think it was anything but the oil viscosity due to moving from FL to Baltimore and the weather changes. I kept the oil changed every 3000 miles, with a local Valvoline center doing all that and never noting anything odd with the oil when they changed it.
New oil pump, new spark plugs and wires, new thermostat, new chain/belt for the pistons or whatever is under those and new pulleys for that part as well, went ahead and gave the ok for a new timing belt and water pump even though I had that done 2 years ago.
Supposedly, they did a manual check of the oil pressure before saying it was the oil pump.
I'm truly at a loss as to what to think now. I asked several times if that was all it was going to need, and every time I was told yes, that would be it, there was nothing else they had found.
Shouldn't they have checked the oil pan before all this?
Old 08 Aug 2016, 05:10 pm
revo's Avatar
Engine bearings protect and support the connecting rod or crankshaft enabling it to spin freely in engine. If a problem accrues will us ally give off two types of sounds a knock which would be a bearing or a sound that sounds like a pice of tin getting hit which would mean it would be a rod. But no noise doesn't fly with me.
QUITE CONFUSED... SNARFUS Tech & Performance Forum 1 12 Jun 2015 01:02 pm
A bit confused IamN00bz General PT Cruiser Discussions 5 07 Apr 2012 02:43 pm
I'm Confused........... PTconquest Turbo Performance 21 19 Feb 2012 03:17 pm
New and Confused gitch Tech & Performance Forum 11 21 May 2011 12:55 am
Someone is a bit confused sakigt Wheels, Tires, Suspension 6 17 Dec 2003 03:02 pm
