Frustrated
Old 19 Aug 2016, 09:57 pm
Default Frustrated
I have a 2004 non turbo. I can't keep it running. Replaced the ecm , speed sensor, O2 sensors, another ecm. Code is always po300 misfire, po0032&38 O2 sensors. The car will run fine for days, then the check engine light will come on, then blink, then die slow and painful, spitting and sputtering until you let off the throttle, then it dies. Anybody have any ideas?
Old 19 Aug 2016, 10:04 pm
Default Re: Frustrated
If the P0300 keeps triggering after resetting with the OBDII Scan Tool I would suggest checking your fuel pressure. It should be 58 +/-5 PSI. Make sure it holds the pressure.
Old 20 Aug 2016, 10:17 am
Check wiring to cam and crank sensors.
Old 20 Aug 2016, 10:51 am
Welcome to the forum
P0300 - Multiple Cylinder Misfire:
Possible Causes:
1. Fuel system problems exist
2. Erratic Camshaft or Crankshaft Sensor signals
3. Ignition system problems exist
4. Engine mechanical problems exist
5. PCM has failed
Post what has been done to diagnose the problem besides what has been posted in post #1.
Old 20 Aug 2016, 11:32 am
Because Trump
Old 22 Aug 2016, 10:45 am
Wolfman01's Avatar
Point me as another recommendation for checking out the fuel pump. This sounds classic to a failing pump. I've experienced the same on and old Dodge Caravan, Hyundai Sonata, and a Ford F150. Pump bearing get worn and don't spin right, pump gets hot and seizes, only to act "normal" for a while once cooled back down.
2018 Jeep Compass Trailhawk
2015 Chevy Colorado Z71 Trail Boss (22k)
2004 Saturn ION Redline (9k)
Old 22 Aug 2016, 12:44 pm
Handy_Cruiser's Avatar
The 2001/2002 PT's have a valve on the left end of the fuel rail that can be used to test fuel pressure. On the newer models you will need a fuel pressure testing kit with an in line adapter or you can make one using fuel fittings and hose. A parts store like Autozone or Advance may have a fuel pressure testing kit in their loaner program. It may or may not come with the adapter you need.
Frustrated beyond belief. please help!!! tarainwonderland Tech & Performance Forum 12 29 Jun 2015 11:40 pm
Very frustrated, please help mechanicallyuninclined General PT Cruiser Discussions 9 30 Jun 2010 01:36 pm
Frustrated with my gauges. help!! sinhenry Interior Accessories Forum 2 17 Feb 2009 06:45 pm
frustrated careyk General PT Cruiser Discussions 6 03 Jun 2008 11:28 pm
just wanted to say hi, and I am frustrated CyanJaguar General PT Cruiser Discussions 8 01 Oct 2003 04:39 am
