Question for the Paint Gurus
Like Tree8Likes
Old 29 Aug 2016, 08:42 am
Gkon's Avatar
Default Question for the Paint Gurus
I recently repaired a tear in my front bumper and then painted it.
The bumper was stock (unpainted) for an '02 Limited Edition.
I sprayed it with 3 coats of Adhesion Promoter
And then 3 coats of Bumper Coating
I've noticed some sanding marks that I didn't fully get out of the bumper before painting. I plan on waiting a week for the paint to fully cure, and then sand that area smooth and repaint. (I figure that I will need to repaint the entire bumper to make sure the color is even, right?).
Here is the question:
After sanding is complete, will I again need to spray 3 coats of Adhesion Promoter prior to the Bumper Coating, or can I just spray on the Bumper Coating?
Is the Adhesion Promoter only necessary when preparing to paint over the stock, plastic bumper, or should it and can it be sprayed over the existing Bumper Coating?
Thanks!
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 29 Aug 2016, 08:53 am
Default Re: Question for the Paint Gurus
At this point you did a great job.
I would lightly sand. Use paintable primer on the area you repair and wet sand with 400. Then lightly wet sand the whole bumper with 600. Re-mask the complete bumper and re-shot with a semi black Krylon
Krylon 51603 Semi-Gloss Black
Spray normally for the first couple of coats. Then your final coat fan spray to give a slight textured finish.
You should not (and I do not recommend )need to use any clear.
I use Krylon super or color max even on Ploy's and they stick like it was bonded into the material. Also on some none auto projects I use synthetic oil and greases for lubricating and the Krylon is not effected by them.
Noted that in many project I respond with Rust-Oleum paints. However regarding plastics and ploy's I have found that Krylon is a better more durable paint to use especially is chemical may come into contact with the material painted.t.
Gkon likes this.
Old 29 Aug 2016, 09:07 am
Gkon's Avatar
Hi Nitro. Thanks for the compliment and the info. It's much appreciated.
I'm sure Krylon is good stuff given your experience with it, but I want to keep the brand and color I've just sprayed (Duplicolor Charcoal Gray), I'm not looking to change it. I just want to smooth out the rough sanding marks that I didn't see till after I painted and then repaint with the same color. I just don't know if I need to reapply Adhesion Promoter over the Duplicolor, or if Adhesion Promoter is only used on bare, plastic bumpers.
Thanks!
Old 29 Aug 2016, 09:49 am
PGBCruiser's Avatar
So I was wondering about cleaning/detailing after this repair is finished (GREAT JOB Gkon!).
Now that the bumpers are coated with the Duplicolor Bumper Coating, are they treated as a painted surface, or is bumper coating a different material which would allow you to use plastic related detailing/protectant products?
I think Nitro may have addressed this in the past on a different thread (once it's painted - it's paint).
I have this on the to do list; and in Florida wax or UV protectant products are a must.
Peter
Gkon likes this.
Old 29 Aug 2016, 10:01 am
Far as the adhesion promoter reapplication. If you sand through the paint spot the area with promoter. And prim or paint as you planed.
Gkon likes this.
Old 29 Aug 2016, 10:06 am
Gkon's Avatar
Peter
I have the same question.
PGBCruiser likes this.
Old 29 Aug 2016, 10:09 am
Gkon's Avatar
Thanks, Busted_PT
So, just to make sure I get it, if I sand through the area back down to plastic, just spot spray adhesion promoter on that area only, and then repaint the whole bumper again. No need for Adhesion Promoter on the still painted surfaces, Right?
(I know, that's what you said, but I just like to be 100%).
Old 29 Aug 2016, 10:13 am
Originally Posted by Gkon View Post
Thanks, Busted_PT
Danny and I are talking live about this hang tight...
Gkon likes this.
Old 29 Aug 2016, 10:17 am
Gkon's Avatar
Awesome! Thanks.
Old 29 Aug 2016, 10:50 am
Soo............. we have 2 thoughts...one is just spray with the final paint and the other is if you cut down to the plastic use the promoter.
There are good reasons and thoughts supporting for either.
Gkon likes this.
Paint question Carzboyz The Detail Shop 12 17 Jan 2014 08:37 pm
Here's a Goodie Question for you gurus - Front Wheel Rekoj Wheels, Tires, Suspension 2 03 Jan 2012 03:18 pm
paint question 4SPEED The Detail Shop 1 08 Feb 2011 11:29 am
engine problem for REAL Gurus or Gearheads 4SPEED Tech & Performance Forum 7 07 Sep 2008 05:22 pm
Paint Question air4cefamily Interior Accessories Forum 5 23 May 2008 06:07 am
