Shouldn't the fan work after stopping the car?
Like Tree10Likes
Old 01 Sep 2016, 05:00 pm
Default Shouldn't the fan work after stopping the car?
Hi everyone!
My PT Cruiser overheated a few times this Summer (I live in Texas and we had very hot days - I have a 2004 PT Cruiser with 160K miles).
I changed the thermostat and that partially solved it - now my car doesn't overheat while I'm driving.
However, if I stop the car for a few minutes and then start it again (say 5 minutes), the temperature goes very high (about 80%) and then stabilizes very quickly.
That led me to think that maybe the fan isn't working as it should. I had other cars where the fan would work for a few minutes after stopping the car, but I can't hear the fan working after stopping my PT Cruiser.
However, the fan seems to work as expected when I turn on the AC. I can hear the fan running.
Any tips would be much appreciated. Thank you!
Old 01 Sep 2016, 05:06 pm
Default Re: Shouldn't the fan work after stopping the car?
My other cars have the fan stay on a minute or two after I turn the engine off, my PT doesn't. As far as that goes, yours is working fine.
rckstein and Fk5 like this.
Old 01 Sep 2016, 05:07 pm
sanatanadharma's Avatar
Because Trump
CREWZIN, rckstein and Fk5 like this.
Posting in stealth will not be permitted in most threads please read the forum guidelines.
Old 01 Sep 2016, 05:18 pm
Fk5 Fk5 is offline
+1
That is normal. As long as it drops quickly once you turn it on that is normal.
rckstein likes this.
2003 GT 5 speed
162,000 miles
Old 01 Sep 2016, 06:27 pm
I would suggest making sure your engine coolant system is sealed. Do a engine coolant pressure test and make sure its holding pressure. Also check the radiator cap.
Old 02 Sep 2016, 08:47 am
Thank you so much for your replies! That gave me some piece of mind.
I will follow the suggestion of performing an engine coolant system check to make sure it is sealed and holding pressure. I will also try changing the alternator cap.
I will report back, thank you!
Old 02 Sep 2016, 09:15 am
rckstein's Avatar
I think you mean radiator cap.
Old 02 Sep 2016, 10:25 am
My fans run after I turn off the ignition.
Posted video many times on this forum that you can hear it after engine is shut off. I have an after market fan controller.
soyomb likes this.
Last edited by CREWZIN; 02 Sep 2016 at 10:41 am. Reason: I have an after market fan controller
Old 02 Sep 2016, 10:44 am
My initial thought, as well. The non-aspirated PT has a single, 2 speed fan. One of the speeds is not working.
2016 Kia Soul Plus Black
Old 02 Sep 2016, 11:43 am
rsrocket1's Avatar
soyomb,
I think you just had your leg pulled
Tags
fan, over heating
Stumbles out of 2nd when stopping MarriedToIt Tech & Performance Forum 10 22 Nov 2015 08:18 pm
Growling when stopping below 20 mph alphanumericone Tech & Performance Forum 5 28 Feb 2011 02:45 pm
Car jerks before stopping jessica2001 General PT Cruiser Discussions 1 30 Oct 2010 05:48 am
