Car will not start
  • 1 Post By _PTGT03
Old 05 Sep 2016, 12:28 pm
Exclamation Car will not start
Hi can anyone else on here tell me if they have problems starting there car if they have a 1/4 of a tank of fuel left.....On mine 2.4 petrol if the fuel is at the 1/4 of a tank gauge and thats not even near red or petrol light. The car will not start. I then back the key off and on say 3 times and let the fuel pump build up and cut off and it will start. Then if i put say 1/2 a tank of petrol in it starts normal. I am at a loss i have to put £30.00 of fuel in so as it will start lol
Old 05 Sep 2016, 12:36 pm
Default Re: Car will not start
Just a guess but it sounds like a problem with the fuel pump. It's inside the petrol tank.
Old 05 Sep 2016, 01:51 pm
What year is your PT Cruiser?
I would suggest you check your fuel pressure. You should be getting 58 +/-5 PSI. You might have a weak fuel pump. When the fuel tank is full with fuel it makes it easier for the fuel pump to keep the fuel pressure needed to keep the engine running.
Old 06 Sep 2016, 01:38 am
_PTGT03's Avatar
could also be an issue in the float sensor and a 1/4 tank is actually representative of empty ! subtract the amount of volume of petrol you poured in to make a full tank once it was 1/4 full to the full capacity of the tank to know for sure.
thecabinguy likes this.
Stalled while driving, key to start, no click or start farmerhope Tech & Performance Forum 30 08 Feb 2016 03:44 pm
Pt just won't start mattie1972 Tech & Performance Forum 6 19 Aug 2013 09:58 pm
My PT Won't Start Rdoggg1111 Tech & Performance Forum 57 01 Mar 2012 08:04 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
