Need 5 star torx for key cyl. housing removal
  • 1 Post By wwpptc
Old 05 Sep 2016, 04:39 pm
Default Need 5 star torx for key cyl. housing removal
2006 PT, Touring Edition, non Turbo, stock, 202k miles.
Thanks to all the info I was able to get on this site I was able to identify an intermittent starting problem, then turned into a wont start problem, as a bad ignition switch actuator pin. Although dealer does not sell the pin for the 2006 PT it appears the Jeep pin will work. Anyway my problem is removing the key cylinder housing. on the 2006 model there are two 5 star torx type screws that hold the housing in place. I am having trouble locating this tool and would like any direction I can get on obtaining the needed tool.
Thanks in advance for any help.
BTW...I tried O'Riely's, Auto Zone, Harbor Freight, going to Sears today to try.
Napa say's they can order a set of them from Carlyle but it would be expensive (did not get exact cost). Dealer does not sell.
Old 05 Sep 2016, 05:34 pm
Default Re: Need 5 star torx for key cyl. housing removal
This set comes in handy.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Original join date: SEP 2003
Steve/ Wayne NJ
2005 GT Vert / Black / 5 speed
2004 Dream Cruiser / 5 speed Traded for 12 Veloster
2003 GT / Blue / Auto /sold
2001 Touring/ Silver / 5 speed /sold on E Bay
Old 05 Sep 2016, 06:03 pm
rckstein's Avatar
Originally Posted by njsteve1 View Post
The bits you show are 6 points, the OP says that he needs 5 point torx, is the OP mistaken and the set you show are actually what he needs?
This is what is stated in the Service Manual:
"1. Using Tamper-Proof TorxT Plus (five point) 30 bit,
remove the two screws (1) fastening the lock cylinder
housing (2) to the column."
Here's the 5 point set:
https://www.amazon.com/5-Point-TORX-.../dp/B007SOODHC
Old 05 Sep 2016, 06:18 pm
LionPT's Avatar
2006, Security screw size for ignition assembly to column ?
Old 05 Sep 2016, 06:26 pm
Here's the Craftsman set I have from Sears. Plus a set of bits with more sizes.
Old 05 Sep 2016, 06:49 pm
If the OP will simply "google" ------ Sears store torx 5-point #30 availability ------ He will find them at Sears, Walmart, etc., etc., etc.
Jerry
rckstein likes this.
On-Star Mirror chiefsfanforever70 General PT Cruiser Discussions 5 28 Jun 2014 05:21 pm
5 Star service Blade General PT Cruiser Discussions 8 06 May 2004 01:52 am
(Non-PT) See Star Wars renichms General PT Cruiser Discussions 4 21 May 2002 05:28 pm
