Oily/petroleum smell at idle, uggh!!
Like Tree9Likes
  • 2 Post By LionPT
  • 2 Post By rcktpwrd
  • 3 Post By egandb
Old 09 Sep 2016, 08:17 am
Default Oily/petroleum smell at idle, uggh!!
Howdy! I'm a noob to ptcruiserlinks, so please forgive and advise me if I'm doing something wrong.
My daughter just bought a 2003 PT Cruiser. She loves it, but she's concerned about an oily/petroleum smell through the car's air vents when it's at idle or when the car is stopped at a light. The smell is present only when the fresh air/recirculation switch is set to fresh air. The engine isn't leaking oil (from what we've seen so far). As far as I can tell, no oil is dripping/leaking onto the exhaust manifold, but to me, that is exactly what it smells like. Has anyone ever dealt with this with their PT Cruiser? I suspect a faulty PCV valve, but also have my doubts that's the issue. Any help would be greatly appreciated!
Old 09 Sep 2016, 08:28 am
LionPT's Avatar
Default Re: Oily/petroleum smell at idle, uggh!!
I would clean the engine (Gunk)...JMO
Old 09 Sep 2016, 08:45 am
You probably have a small oil leak that's hitting something hot and causing the fumes to go inside the cabin when you draw fresh air.
Old 09 Sep 2016, 03:44 pm
rcktpwrd's Avatar
The valve cover gasket tends to leak a tiny bit as these cars get older. It's about $30 for a new gasket set and can take a couple hours to change out. Not hard to do just time consuming...
rob302 and egandb like this.
Joel
www.rcktpwrd.com
Old 02 Jan 2017, 09:04 pm
rcktpwrd, turns out you were correct - it did end up being a leaky valve cover gasket.
Thanks for the idea and advice!
Old 02 Jan 2017, 09:25 pm
rcktpwrd's Avatar
Cool Re: Oily/petroleum smell at idle, uggh!!
glad you found the problem and were able to fix it!
Joel
www.rcktpwrd.com
Old 02 Jan 2017, 11:57 pm
Yikes! Good catch.
Old 05 Jan 2017, 10:58 am
FeelthySanchez's Avatar
Just nuttz. The last "tech" in there was an absolute HACK.
No mention of any oil loss, but it had to be extreme - on the order of 1qt/week.
Orig owner 100% stock Patriot Blue 2001 LE 5-spd: 283,760 miles & rolling well on it's 3rd ECM, 2nd engine, 3rd gearbox, 2nd rack & pinon.
"The idiot's guide to passing yourself off as leadership" - Ed Hipalito. Author, mgmt failure, narcissistic buffoon.
Old 05 Jan 2017, 11:54 am
Handy_Cruiser's Avatar
Good mechanics are hard to find.
Tags
air, oily, smell, vent smell
New here--Rough Idle & Weird Smell JenR1974 Tech & Performance Forum 11 07 Apr 2015 11:29 am
'03, rough idle, smell coolant bbromero General PT Cruiser Discussions 2 22 Feb 2010 02:21 pm
Oily smell from air vent when idling Art Rigby Tech & Performance Forum 4 30 Jul 2004 11:15 am
Petroleum or Synthetic Oils Art Rigby Tech & Performance Forum 9 29 Jul 2004 09:51 pm
Synthetic vs. Petroleum Based Oils GTcamster Turbo Performance 8 18 Apr 2003 07:32 am
