key/fob doesn't have trunk release, what is needed for remote trunk release?
Like Tree7Likes
Old 11 Sep 2016, 11:14 am
Default key/fob doesn't have trunk release, what is needed for remote trunk release?
just wondering if it is as simple as getting a 3 button remote, or do I have to get another RKE or other stuff? I have a 2006, thank you
Old 11 Sep 2016, 11:31 am
Default Re: key/fob doesn't have trunk release, what is needed for remote trunk release?
If the key fob locks and unlocks the doors does it not unlock the trunk when you hit the unlock button a couple of times? Possibly, you have a problem with the trunk (lift gate) lock itself and not the key fob.
Old 11 Sep 2016, 11:41 am
rckstein's Avatar
Welcome to the forum
How long have you owned your PT?
There's a touchpad switch under the rear hatch handle that may be faulty, or the electric latch mechanism could also be faulty. To troubleshoot either, you'll need to remove the rear hatch panel.
Old 11 Sep 2016, 12:13 pm
sanatanadharma's Avatar
Because Trump
Posting in stealth will not be permitted in most threads please read the forum guidelines.
Old 11 Sep 2016, 12:32 pm
rckstein's Avatar
Originally Posted by sanatanadharma View Post
Do you want a hatch release or a hatch unlock?
If you run some wires, and if you get a proper key fob, and if the RKE has a functional trunk release program, then by adding a different hatch-latch or an additional solenoid motor and linkage, then yes you can do it.
See here for engineering marvels
His PT should already have an electric hatch mechanism in place, it's listed as standard equipment on all trim levels.
Old 11 Sep 2016, 03:10 pm
I have the combo key/fob (key with buttons) and when I press the unlock button twice it doesn't pop the tailgate
The other issue I have is the touchpad not working half the time when I want it to and most of the time when I go to leave I have to re-latch the hatch
I'm going to be putting in a momentary switch to bypass the touchpad
also I'm going to be adding a trunk release button in the dash (well maybe, bought it on Amazon just now) don't know if it has wiring for it or not
thanks all for your help
Old 11 Sep 2016, 03:52 pm
rckstein's Avatar
The rear hatch won't "pop" until you press the touchpad switch.
This is the switch that I recently installed after the touchpad switch broke on my PT:
It is a momentary contact 12VDC weatherproof from AutoZone. I also added on the inside and outside of the switch a O-ring to seal and then the fiber washer on the inside to distribute the pressure from the mounting nut, because the entire handle/cup area is plastic.
If you notice the switch is mounted slightly off-center and that's because at the top of the switch you see a post and nut. That is one of the mounts for the handle/emblem assembly. If the switch was mounted exactly on center depending on the switch you get, the switch could make contact with the stud and nut. But being slightly off-center works perfectly because from the outside, when you put your hand in the cup area like you would touch the touchpad switch, your middle finger (being longer) touches right where the switch is. The fix cost about $15 in parts and a little labor and certainly cheaper and much easier than replacing the entire handle/emblem assembly.
Old 11 Sep 2016, 04:05 pm
Because Trump
Old 13 Sep 2016, 03:06 pm
does the key fob unlatch the hatch or simply unlock it? I'm guessing it does it after you press it twice like the older ones with the separate fob's - It doesn't do this so I'm guessing I have an issue with the system somewhere (although it has randomly unlocked the hatch, I have heard it, then went and shut it, this is without pressing the unlock button, so I'm guessing the touchpad is borked)
thanks for the help
(I'm putting over $1500 in parts to replace the entire suspension, the clutch, timing belt kit and other things to get it in great shape, might even paint it as the burgundy paint has gotten hammered by the FL sun for 10 years)
Old 13 Sep 2016, 03:33 pm
rckstein's Avatar
thanks for the help
You won't hear the rear actuator unlatch until you press the touchpad switch. To troubleshoot either the latch mechanism, or touchpad switch, you will need to remove the rear hatch interior panel.
Trunk Release jonestl99 PT Cruiser Convertible Forum 58 11 Apr 2015 06:23 am
FYI how I diagnosed and repaired dysfunctioning lift gate remote release ptprice Tech & Performance Forum 0 27 Dec 2014 08:31 pm
Give Me Some Release! (Deck Lid Release) GTCRUISER2006 General PT Cruiser Discussions 4 20 Feb 2012 12:30 am
Trunk release safety atlptc General PT Cruiser Discussions 1 19 Aug 2009 08:34 pm
Remote Hatch Release Bobster Exterior Accessories Forum 1 03 Apr 2008 05:31 am
