clutch went out which brand should i use and what
Old 18 Sep 2016, 09:46 am
Default clutch went out which brand should i use and what
all do I need to replace while I got the trans out. my pt is a 2003 . I figure
1 the clutch assembly
2 axle seals
3 transmission mount
4 transmission fluid
5 the clutch slave cylinder(still works good so im on the fence about this one
6 shifter cable bushings
my pt has 134k miles. im going to buy new shocks and struts while im at it
my car will be used in the city and highways and sometimes will be used to tow a trailer
Old 18 Sep 2016, 11:19 am
Default Re: clutch went out which brand should i use and what
I would look at getting another good quality throwout bearing.
Old 18 Sep 2016, 11:27 am
rob302's Avatar
I would skip the trans mount and slave cylinder. Save your money. I would leave the slave hydraulic line attached unless you buy the master and slave together as a pre bled kit.
I used the $145 clutch on rock auto and I beat the hell out of it. Worked fine for me.
Old 19 Sep 2016, 01:29 am
_PTGT03's Avatar
can get all your parts at rockauto . i went with the solid flywheel conversion kit but that costs a little more. the clutch slave piece snapped when it was shipped although, so i just re-used my old one which worked fine.
the solid flywheel conversion will give you a better performance feel since the dual-mass clutch absorbs and wastes energy.
Do I need a new clutch? n3tjm General PT Cruiser Discussions 6 20 Jul 2016 11:27 am
Clutch Energyman Tech & Performance Forum 3 13 Jul 2016 01:14 pm
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
