P0320 P1684 codes
Like Tree2Likes
  • 1 Post By ptcruisersteve
  • 1 Post By WingMD
Old 20 Sep 2016, 11:14 am
Default P0320 P1684 codes
2002 base model 5-speed non turbo 118000 miles.
Car hesitated briefly one day then shut off while driving about 45 mph in 5th gear.
Pulled over, tried to start it twice but it wouldn't fire up.
Checked timing belt - not broken.
tried to start again - started right up and drove home.
Threw codes P0320 (Crank sensor) and P1684 (battery disconnected recently)
Weird. Why did it start up on the third attempt?
Maybe limp mode? No check engine light though.
Disconnect crank sensor connector. Would not start.
Reconnect crank sensor. Starts right up.
Notice wiring by camshaft sensor is very damaged by oil leak and bare copper is showing. Tape it up with electrical tape and clean oil from area.
Clear codes by disconnecting battery. P0320 is gone. P1684 still there (at least P1684 makes sense this time).
Car drives fine around neighborhood.
Any ideas?
2002 base model 5-speed aka the lowest-end Chrysler you could buy in 2002.
Old 20 Sep 2016, 11:21 am
Default Re: P0320 P1684 codes
Welcome to the forum.
You might want to introduce your self and post some pictures of your PT Cruiser.
I would suggest that the wiring going to the crankshaft sensor might be bad internally causing intermittent ignition timing failure.
Busted_PT likes this.
Old 20 Sep 2016, 11:42 am
Also on these models the wiring can get damaged because it's near the axle shaft. The sensor could be good. Given you have these two codes together. That is going to be your problem. Happened to many such as the moderator CREWZEN. If it hanging lose I would inspec it carefully.
Old 22 Sep 2016, 05:32 pm
Upon visual inspection the wiring appears to be well away from the axle and no signs of rubbing are apparent.
The Crank and Cam sensors were replaced with Non-Mopar parts from PepBoys about 5 years ago. Has anyone experienced intermittent trouble before a sensor finally dies?
I'm thinking of just replacing the car. My K frame is in very bad shape due to Upstate NY road salt just savagely destroying everything it touches.
Old 22 Sep 2016, 06:12 pm
Considering you found the wiring damaged going to the crankshaft sensor I would unplug the wire connectors at both ends of the crankshaft sensor wire and check it with an ohm meter. Wriggle it while looking at the ohm meter and see if there is a change in resistance.
Old 04 Oct 2016, 07:04 pm
I ended up installing a new crankshaft sensor and everything seems okay so far!
Fk5 likes this.
Old 04 Oct 2016, 07:23 pm
Fk5 Fk5 is offline
Glad it seems fixed. I think the cam and crank sensors are basically Hall effect sensors. I have had plenty of experience with intermittent problems with them as distributor triggers in older mopars. They often would start working again when they cooled.
2003 GT 5 speed
162,000 miles
Old 05 Oct 2016, 07:26 am
I am just wondering out loud here. Is there any such thing as "limp mode" in a five speed PT? I thought that just applied to the automatics.
Old 05 Oct 2016, 09:11 am
Chuzz, it was posted "maybe limp mode?" so the member WindMD was only guessing at that time what might be happening to the PT Cruiser.
Old 05 Oct 2016, 04:55 pm
I realize that, Steve. I'm just wondering if a manual can actually become stuck in 2nd gear if something goes wrong with the PCM or TIPM. Do you know if that's possible with a manual shift? I wouldn't think so, but with computers controlling so much nowadays, who can say, right?
Help me please! P1684, P0117 & P0320 bananabond Tech & Performance Forum 12 09 Apr 2013 07:15 pm
Car just died. Codes P0320 and P1684. Help? Khmer75 General PT Cruiser Discussions 5 15 Apr 2012 10:20 pm
Error Codes P1388 and P0320 baldbryn Tech & Performance Forum 1 30 Oct 2011 05:04 pm
codes p1684 and p 0551 PTCHANDLER General PT Cruiser Discussions 3 06 Dec 2010 04:42 pm
Codes p1684 and p0340 xodeflepgirlox Tech & Performance Forum 1 08 Oct 2010 07:46 pm
