2006 Trunk constantly releases
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By rckstein
Old 21 Sep 2016, 03:54 pm
Default 2006 Trunk constantly releases
Trunk releases when stopped and when moving MOST of the time. Relay?
Latch? Car is all power with remotes etc. When inside locking the doors seems to eliminate the problem
Hopefully someone can help the mechanical challenged guy.
Old 21 Sep 2016, 04:36 pm
Default Re: 2006 Trunk constantly releases
Here's a couple things I found in a search...
lift gate keeps opening itself
https://answers.yahoo.com/question/i...4032359AASyPVn
Old 21 Sep 2016, 09:23 pm
CREWZIN, thanks, great help and what a fantastic PT you have.
Old 21 Sep 2016, 09:28 pm
Thanks. Hopefully there's somethng in those links that can help you figure out what's wrong.
Old 21 Sep 2016, 11:56 pm
rckstein's Avatar
I would bet your touchpad switch has failed, or is in the process of failing, and momentarily triggering on its own and unlatching the latch mechanism. If you wanted to see if it was the touchpad switch, you could remove the rear hatch inner panel and unplug the switch. Then drive around as normal for a while and see if the hatch still unlatches on its own. If it doesn't, then it would be the touchpad switch that is the cause.
Mine recently failed and instead of replacing the entire emblem/handle assembly, which is what is required to replace the switch, I installed a second switch under the handle assembly, cost about $15 in parts and work great!
Old 22 Sep 2016, 12:07 am
You'd have to change all that hardware?? That's insane ... is there a fuse, for it???
Pull the fuse (if there is one) call it day ... worry about it later.
Old 22 Sep 2016, 12:26 am
rckstein's Avatar
Don't know if there is a separate fuse for just the rear hatch, if there is a fuse for the locks, it would most likely control all the locks, so if you remove the fuse, then all the door locks would stop as well.
If you did find out that the touchpad switch is bad, I guess you could just leave it unplugged, and then you would have to use the key everytime you wanted to unlatch the hatch?
Old 22 Sep 2016, 08:11 am
LionPT's Avatar
With the doors unlocked & driving, do all the door auto lock when you hit 15 MPH..??
Also with the car off & doors locked w/alarm on, unlock the rear hatch with the key. Does the alarm go off..??
2006 Trunk constantly releases westernslopePT Mountain PT Forum 1 12 Oct 2016 04:59 am
PCM or TCM? Constantly changing codes! TheFox Tech & Performance Forum 6 01 Jun 2016 01:34 pm
MegaSquirt Releases a 41te ATX Controller UptownSport Tech & Performance Forum 0 27 Jan 2011 11:17 pm
Radio Constantly Skipping. Cathy06PT Sound and Security Forum 3 27 Mar 2009 10:59 pm
Trunk and trunk rack for the PT Cruiser jy_cruiser Exterior Accessories Forum 0 29 Oct 2001 10:32 am
