08 Pt Cruiser- starting issues
Old 30 Sep 2016, 04:22 pm
Default 08 Pt Cruiser- starting issues
Turn key and get a clicking noise. The click sounds like it's the starter. I'm no mechanic, and don't know all the correct terminology. Here's what I have replaced fixed so far. I replaced the battery. I replaced the starter. I have confirmed w a voltage meter that the starter is getting sufficient amps. I thought it might have been the starter relay. I swapped it with the other relay (not sure what it's called) same issue. My only other thought, based on other PT posts is to replace the ignition switch. Anybody have any other suggestions?
Old 30 Sep 2016, 04:35 pm
Default Re: 08 Pt Cruiser- starting issues
Yes, I have a suggestion. Check the ground cable connector behind the battery on the driver side fender. Might be loose, dirty or broken. Look closely and clean it up and tighten it anyway.
Old 30 Sep 2016, 04:58 pm
I would suggest checking voltage going to the solenoid from the ignition switch and make sure you are getting 12 volts.
Tags
starter issue, starter problems. pt
PT Cruiser Starting Issues sharkeish Tech & Performance Forum 4 13 Apr 2015 05:18 pm
PT starting Issues SaberLima General PT Cruiser Discussions 1 04 Sep 2013 11:59 pm
HELP! 2003 PT Cruiser On-going Problem with Starting Issues Nanner Tech & Performance Forum 7 05 Jul 2012 11:59 pm
2002 Pt cruiser starting issues ort102 Tech & Performance Forum 5 11 Jul 2011 07:28 pm
01 PT Cruiser starting issues rampagent69 Tech & Performance Forum 1 28 Jun 2011 09:12 am
