2006 Pt Cruiser wont start
Old 02 Oct 2016, 09:34 pm
Unhappy 2006 Pt Cruiser wont start
Hi all, long time reader, but I finally joined.
I have a 2006 pt cruiser limited. 134k miles.
My pt won't start. Battery is new. Alternator and starter rest good. Recent oil change (2 weeks ago) new spark plugs, new cam shaft sensor. Tried an old trick using starter fluid- didn't work. On my last working run there were no issues (check engine light not on) when this issue occurred, the car started fine and as I was going to put it in gear to leave (had not touched shifter yet) it died and wouldn't start. It starts, but wont turn. Any advice? What else can I check?
Old 02 Oct 2016, 09:36 pm
Default Re: 2006 Pt Cruiser wont start
Has the timing belt been changed?
Old 02 Oct 2016, 09:37 pm
LionPT's Avatar
What do you mean by it starts but won't turn..??
Old 03 Oct 2016, 12:59 am
Welcome to the forum.
I would suggest checking to see if your timing belt is working properly.
Remove the camshaft position sensor, have someone turn the engine over and see if the camshaft is turning.
Old 03 Oct 2016, 08:17 am
Timing belt and water pump have been changed out - about 3 months ago.
Cam shaft sensor removed and I can see ithe nside turning.
As for starting, ummm, I'm not sure on terminology. It sounds like it wants to start, - it cranks bit doesn't turn over.
Old 03 Oct 2016, 08:57 am
I would suggest taking the camshaft position sensor connector off and see if it triggers the P0xxx for it. You should be triggering codes.
Old 03 Oct 2016, 10:23 am
About a week ago, I took it to get battery, alternator, starter checked and I got a p0882 code. This was before this issue started. I have replaced the battery since.
Old 03 Oct 2016, 05:01 pm
Also, I can hear the feul pump spin for a few seconds when I turn the key 1/2 way.
Old 03 Oct 2016, 06:11 pm
My sister's fiancÚ tried a trick with battery and connecting it to a sparkplug. There was no spark. Could it be the crankshaft sensor? Is it easy to change?
Old 03 Oct 2016, 10:37 pm
_PTGT03's Avatar
cranking and turning over are the same. i suggest a dictionary
Tags
2006 pt cruiser, not starting
PT Cruiser wont Start blendy1303 Welcome New PT Cruiser Members 3 05 Feb 2016 08:17 am
2006 base model wont start jclayton973 Tech & Performance Forum 7 26 Jan 2014 04:15 pm
2006 wont start, battery is good Samson Tech & Performance Forum 13 26 Apr 2011 03:00 pm
07 Cruiser Wont Start! 07fastptloser General PT Cruiser Discussions 1 15 Feb 2011 06:52 am
2006 Touring Ed. wont start.... help!!!! marvinev General PT Cruiser Discussions 4 18 Feb 2010 06:42 pm
