Clunk in rear of car.
  • 1 Post By NitroPT
Old 04 Oct 2016, 11:00 am
Default Clunk in rear of car.
How much trouble is it to replace the Watt's Link in my rear suspension? There's been a clunk sound from the rear since I've had the PT and have decided the link is the culprit. Can I do the change out in my driveway or do I have to take it to my usual shop to get it done? Are the links on eBay comparable to the originals? Should I use all new hardware? All advice will be appreciated.
Old 04 Oct 2016, 11:18 am
Default Re: Clunk in rear of car.
Very easy job that can be done in a driveway or "dirt" yard.
I recommend that you replace the bolt when you replace the bell crank.
VsandFords likes this.
Old 05 Oct 2016, 09:29 am
There is a video on you tube. Might want to watch as there are some tools you may not have.
Good luck!
PS check the spare tire is tight
Mike
Old 05 Oct 2016, 12:46 pm
I did mine a few months back on my drive - it's a fairly straightforward job, especially if you change the link bars at the same time. Then you only have to undo each link bar where it bolts to the chassis and the centre bolt on the Watts link and remove the assembly in one piece. This saves having to split the two link bar joints at the Watts linkage.
Only real thing to be sure of is that you check the orientation of the linkage when you put it all back together, there is a right and a wrong way.
Oh, and if you do do it at home, make sure the car is properly supported before diving underneath. A jack would be too risky, as you have to get a good way under the car to access everything!
2002 PT Cruiser 2.2 CRD
clunk clunk durango Tech & Performance Forum 11 01 Aug 2016 10:26 am
Rear end "clunk/thunk" joshuhwha General PT Cruiser Discussions 9 18 Mar 2015 12:40 pm
Clunk and creak in the rear end. Crid General PT Cruiser Discussions 9 17 Jun 2013 10:42 am
2005 turbo GT convertible rear clunk Deeno General Turbo Discussions 0 29 Apr 2013 07:06 pm
New LCA's and still have a clunk... Jetta02awp Wheels, Tires, Suspension 0 24 Jul 2010 07:13 pm
