ENGINE LIGHT Power steering
Old 04 Oct 2016, 01:36 pm
Default ENGINE LIGHT Power steering
Engine light came on today. Got home put a scanner on it the code was P0551 the scan tool said power steering presser sensor. The Haynes manual gives for the code, incorrect power steering switch input detected. Correct amount of fluid in reservoir on checking. Ideas please ? New switch needed? Anyone had this and cured it? Thanks in advance
Old 04 Oct 2016, 01:52 pm
VsandFords's Avatar
Default Re: ENGINE LIGHT Power steering
My 01 is throwing that code. My pressure switch is leaking fluid, so I thought that was the reason for the code. No, I have not replaced it at this time. Steers good and not leaking fluid, the switch is just wet.
Old 04 Oct 2016, 02:38 pm
P0551 - Power Steering Pressure Switch Circuit Failure:
Possible Causes:
1. Power Steering Pressure Switch sense circuit is open or is shorted to ground
2. Power Steering Pressure Switch ground circuit is open
3. Power Steering Pressure Switch is damaged or it has failed
4. PCM has failed
Have you checked the wiring and contacts going to the Power Steering Pressure switch?
Old 04 Oct 2016, 02:47 pm
Easy to change out but very messy job.
No power steering and battery light win717 Tech & Performance Forum 8 09 May 2014 10:24 pm
Loss of power steering, brakes & rough engine hotinhavasu Tech & Performance Forum 1 30 Nov 2013 01:55 am
Engine light on / Power Steering issue? Artista General PT Cruiser Discussions 5 13 Jun 2013 04:47 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Engine Oil Linght On and Power Steering Leaking cespn General PT Cruiser Discussions 1 05 Oct 2008 07:52 am
