2002 PT oil leak
Old 04 Oct 2016, 05:21 pm
Default 2002 PT oil leak
Hi fellow PT owners from New Zealand.
6 years on from buying a Friday afternoon lemon, another $NZ4000 bill looms.
Can anyone explain what part is missing from the photo showing here.
The picture shows to the right of the torchlight, a gap between the head and block oil return line(?).
This view is from the front of the car looking directly at the engine, 2.0L, just near the end of the starter motor.
The gap is about 2mm wide.
Anyone offer any fix method other than stripping the whole engine (again!)
Old 04 Oct 2016, 05:40 pm
Default Re: 2002 PT oil leak
If it is leaking from between the two pieces there should be a gasket. If you have one and want a temp solution. Clean the area very good, then smear some RTV on the area. Push it into the crack and all around that seam. If the area is dry enough and you stuff it in enough, you might just stop the leak. 7/10 it doesn't work, but pair it with some oil stop leak. You just might get it.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Oil Leak on Fresh rebuild of 2002 Engine BadLucky777 Tech & Performance Forum 4 12 Sep 2016 05:27 pm
2002 PT Dream Cruiser Interior Leak patsslab General PT Cruiser Discussions 6 10 May 2013 09:14 pm
2002 Dream Cruiser with leak at hatch patsslab General PT Cruiser Discussions 1 03 May 2013 07:56 am
Oil Leak, Vacuum leak Ikster Tech & Performance Forum 1 02 Jan 2013 09:53 pm
Oil Leak PT Woody Tech & Performance Forum 10 21 Jan 2005 12:43 am
