Torque setting
Like Tree5Likes
Closed Thread
Old 08 Oct 2016, 11:36 am
Default Torque setting
Can someone please tell me the torque settings for the 10 mm bolts that go in the fluid pan on the autotrans I am looking at the section that covers this in the haynes manual but cant find it If you could let me know or the page number its on I would be grateful. Thanks
Handy_Cruiser likes this.
Old 08 Oct 2016, 11:48 am
Default Re: Torque setting
FYI most all repair manuals have pages that show general torque values for fasteners which will assist with question regarding torque values.
ATX A604/41TE 165 in.lbs.
rob302 likes this.
Old 08 Oct 2016, 12:03 pm
Note that that is inch pounds
Old 08 Oct 2016, 12:14 pm
Yes thanks for that, but the Haynes ones have them all over the place. Not like factory manuals who have dedicated pages
Old 08 Oct 2016, 12:25 pm
I "think" with the Haynes manuals the torque specs are located on the first page of whatever chapter your looking at???
Old 10 Oct 2016, 08:44 am
Please re-read what I said about torque values.
Old 10 Oct 2016, 12:13 pm
The factory service manual says to lay a bead of RTV silicone, snug the pan, and then torque it down after 24 hours.
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Old 10 Oct 2016, 12:34 pm
?? what PT Cruiser FSM is that?
Even All Data has a torque setting.
You may re-read FSM the next part after
"Apply an 1/8" bead of Mopar ATF RTV (MSGF41) to oil pan and immediately install to case.
Install oil pan-to-case bolts and torque to 19N-m (165 in. lbs)
Referance 81-370-05061B
21-365 41TE Automatic Transaxle 66-67
Also ATSG UPDATE Handbook has lots of information regarding issues and procedures.
Chilton repair manual also stipulates that to use the listed factory torque for the transmission pan bolts.
#20390 1-27
Old 10 Oct 2016, 01:21 pm
Handy_Cruiser's Avatar
Here you go.
PS: I believe you can download a complete service manual that covers your 2002 Euro PT at this link:
http://www.mediafire.com/file/lmvdwn2nywm/01-04CPTC.pdf
Old 10 Oct 2016, 01:36 pm
Yep. You are correct. That's what the Chrysler service manual says about the RTV. But the manual I have doesn't say anything about waiting 24 hours.
However, I personally prefer to use a bead of RTV to fix a paper gasket to the pan. This helps fill in irregularities that may be on the pan or transmission case facing. I've done this many time on this type and other transmissions and have never had a leak or problem unless there was a crack in the case.
VsandFords likes this.
Closed Thread
Spark plug socket size and torque setting on plugs KingKole02 Tech & Performance Forum 28 09 Feb 2014 06:49 pm
Frustration setting in Chris70 Wheels, Tires, Suspension 5 22 Feb 2013 01:17 pm
Torque setting for Manifold? jhn_plsn Tech & Performance Forum 15 08 Mar 2011 02:35 am
Setting The Inside she_so Interior Accessories Forum 4 22 Mar 2009 05:19 pm
Setting new standards turbomangt The Detail Shop 0 03 Jul 2004 08:34 am
