manual shift cables aluminum bushings
  • 1 Post By rob302
Old 10 Oct 2016, 11:24 am
Default manual shift cables aluminum bushings
what is the pros and cons of using them. i found some on ebay. i was thinking of getting some for my pt
Old 10 Oct 2016, 12:10 pm
Default Re: manual shift cables aluminum bushings
I would have to ask what holds them in the cable end and what holds the shifting pin in the bushing?
The rubber and urethane ones rely on the rubber to give and snap into place. I'm not seeing how that would work with aluminum.
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Old 10 Oct 2016, 12:15 pm
here is the link
1995 2005 Dodge Neon Shifter Cable Bushings PT Cruiser Stratus Gtcruiser | eBay
Old 10 Oct 2016, 12:19 pm
rob302's Avatar
the pros IMO are the crispness of how the shifter would feel.
on the flip side,
they may transmit extra vibration through the shifter, possibly to the point it'll rattle. if you shift like a you're speedracer, you'll cause more wear on the parts in the trans. this means the bronze bushings in the trans housing that likely already leak will wear quicker, you may wear out the shift fork pads quicker, you may even break a shift fork, or the plastic ends off the shift cables.
i used the stock bushings and had no problem shifting with my foot firmly pinned to the floor. a few times i even managed to rip the knob off the shifter yanking it into second. once i even managed to throw the shift knob into the cargo area.
VsandFords likes this.
Old 11 Oct 2016, 05:42 am
When I had to replace mine I also was concerned about the wear transfering to a more expensive part so stayed with the OEM.
Old 11 Oct 2016, 10:50 am
_PTGT03's Avatar
I heard the prothane replacement bushing kit does a great job though
For Sale: Aluminum Door Lock Pulls+GT Automatic Shift Knob. TangerineDream76 Classifieds: For Sale/Trade 8 17 Nov 2016 12:51 am
Manual shifter bushings? jrunner Tech & Performance Forum 8 07 Aug 2015 12:03 am
Manual shift knob atracats Interior Accessories Forum 10 30 Sep 2011 09:21 pm
01 PT / Touring - manual transmission shifter cables fianafail Tech & Performance Forum 2 17 Sep 2010 08:32 am
Shift balls for manual transmission..... thegoldpt Tech & Performance Forum 6 11 Nov 2005 03:16 am
