Rear latch hidden button broke and a tire PSI question
  • 1 Post By story97
Old 15 Oct 2016, 06:19 pm
Default Rear latch hidden button broke and a tire PSI question
Was at a store, pushed the button to raise the rear hatch. Worked no problem.
Got home to unload and now the button is pressed in permanently and i have to use the key to open the door. not good.
Does anyone know of a trick to pop the button back out? i tried but couldn't get it to move.
I also have one other question.
Due to the obviously young kid that had this car before me, he put wheels on that require a tire that's 205/50R17 and obviously not cheap.
I got the cheapest tires I could find, but for the life of me i can't find the recommended PSI. I do see a max psi but that can't be the normal?\
this is what the tire specs I found on the web say. but 44 psi? that can't be normal operating pressure right? i figured between 30 and 35 somewhere
Product Specs:
Part #: GPS12
TIRE SIZE: 205/50R17
SPEED RATING: V
LOAD INDEX: 89
LOAD RANGE: SL
UTQG: 380 A A
TIRE WARRANTY (U.S.): 50,000 mi.
SIDEWALL: SBL
TREAD DEPTH: 10/32 in.
RIM SIZE: 17 in.
MAX LOAD (SINGLE): 1280 lb.
SERVICE DESCRIPTION: 89V
WARRANTY: Limited
MAX PRESSURE (SINGLE): 44 psi
OVERALL WIDTH: 8.4 in.
Old 17 Oct 2016, 07:44 am
Default Re: Rear latch hidden button broke and a tire PSI question
I guess you have a 2005 or newer PT with the touchpad to open the hatch. There is a thread on this right here that shows how simple it is to put in a $2 Radio Shack switch. Or you could replace the touchpad if you want to spend the bucks. The thread covers both options.
Liftgate touchpad replacement
The tire pressure should be 35 PSI cold.
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Old 17 Oct 2016, 07:50 am
Holy mackerel that's perfect. I'll do the long version for sure.
this is exactly what I was hoping to find. thank you!
and yes, it's a 2007 base
Rear pass. seat release button broke Help hoppyloop General PT Cruiser Discussions 8 15 Aug 2015 01:36 pm
rear latch handle jadmiral Exterior Accessories Forum 3 05 Jul 2015 05:31 pm
Rear Door Latch Help DJStorm Tech & Performance Forum 1 19 Jul 2013 07:37 pm
Rear latch Problem Catching outfit Interior Accessories Forum 2 15 Feb 2012 11:10 pm
Rear hatch latch issue oldcoach General PT Cruiser Discussions 0 30 Jul 2007 10:00 am
