All gear indicators on and won't start
Old 18 Oct 2016, 04:32 pm
Default All gear indicators on and won't start
I got a pt turbo and all gear indicators are boxed and car won't start..the starter sounds like it's trying to activate and had starter tested and is fine..but acts like it won't start because in gear even if shifter is in park...if I disconnect battery it'll go back to normal..but then will light gears and not start again...please help.. I'm totally lost now..for next steps
Old 18 Oct 2016, 06:11 pm
Default Re: All gear indicators on and won't start
Welcome to the forum.
I am suggesting that your TCM might not be processing a valid gear position.
I would suggest checking your wires and contacts going to the TCM. Your TCM might not be communicating with the PCM. Sometimes the battery fluids drip down below the battery support plate and starts getting on the wires going to the TCM. Also check the ground wire.
Indicators flashing. Why? NLAlston General PT Cruiser Discussions 2 08 Aug 2016 04:05 am
INDICATORS TURN SIGNALS HAZARDS PATGAS Tech & Performance Forum 9 29 Oct 2013 04:59 pm
indicators and wipers BogleLodge Tech & Performance Forum 3 28 Dec 2012 03:36 pm
New Multifunction Switch but still no indicators/hazards. Please help! vard3n General PT Cruiser Discussions 4 28 Aug 2009 12:08 pm
