Sway Bar Torque Specs
Old 19 Oct 2016, 03:16 pm
Default Sway Bar Torque Specs
Okay, I have a quick question. Can anyone confirm that the 21 ft lb torque spec I found for the sway bar and end links is correct? Doesn't seem like much torque to me. I managed to get the sway bar bushing cover to 21 ft lb, no problem, but can't get the end links to torque without bulging the bushings, so I just tightened them until the bushing is the same diameter as the washer.
Old 19 Oct 2016, 04:34 pm
rob302's Avatar
Default Re: Sway Bar Torque Specs
28NM converts to 20.65ft/lbs
Old 19 Oct 2016, 04:38 pm
rob302's Avatar
and (not that it really matters) but the correct way to install the bolts is with the bolt head on the bottom and the threads pointing up. this way when you go crazy and start launching curbs and boulders, you don't mess up the threads.
Old 19 Oct 2016, 05:26 pm
I tried installing the bolts with the thread up, rob, but the passenger side rubs the cv boot. So, I turned them around and the nut is on the bottom. I need to retry the torque on the end links now. I didn't realize they needed to be bearing a load before torquing. Thank you very much. BTW, the Mustang is off the table for now. NOT economical enough for Phil. Thanks for the input.
LCA Torque Specs chuzz General PT Cruiser Discussions 4 29 Mar 2016 11:53 am
Torque Specs UZ4PLAY Tech & Performance Forum 15 02 Aug 2012 12:30 pm
Torque specs hidinginparadise General Turbo Discussions 1 19 May 2011 02:32 pm
torque specs gokart Tech & Performance Forum 2 15 Apr 2009 01:46 pm
torque specs? youngcruiser Tech & Performance Forum 8 21 Mar 2006 03:49 pm
