What is this?
Old 19 Oct 2016, 10:51 pm
MrMister's Avatar
Default What is this?
So last Sunday I was changing the oil and filter on the PT, after that I decided to rotate the tires. While taking of the tires I also started inspecting the brakes and the bushings. While doing that, that's when I found this.
What is this and I know I'm gonna have to start making preparations to change them, correct?
Dream Theater - Morning comes to early and night time falls to late...
Old 19 Oct 2016, 11:31 pm
bubba_1952's Avatar
Default Re: What is this?
They are called bump stops and you can get them at the dealership pretty reasonable. They just push/twist into place, no tools needed to install them.
You can also order from Parts House as well.
2004 Limited Edition Platinum Series Dark Graphite Metallic Clearcoat Turbolight A/T
Old 20 Oct 2016, 04:14 am
RickinPA's Avatar
As bubba said, the bump stop. Here's a picture of one (looks like RockAuto is out of stock):
Your picture is what polyurethane looks like when it rots. Time to replace.
Old 20 Oct 2016, 06:39 am
Here's a pic of mine. I cut the end "bump" off to accommodate for the lowered springs.
Old 20 Oct 2016, 07:59 am
rckstein's Avatar
The actual term Chrysler uses is:
BUMPER, Jounce
